03 954RR Suspension Reset - Honda Motorcycles - FireBlades.org
post #1 of 6 Old 01-08-2015, 2:54 PM Thread Starter
Hey everyone, I was wondering if someone could assist me in resetting my suspension height. When I bought the bike I was told it was lowered by 2 inches. The problem however is, I'm not sure exactly how it was done. Included are the pictures of my bikes dog bones and it's current suspension settings. When I texted the seller recently, he said his buddy did the work for him but when he watched he said that he spun a triangle piece and tightened it back up. It was also on a jack he said to lift the rear up. He gave me another pair of dog bones that he said were never used. The current dog bones say MCJGFR on them and with a little bit of research appear to be the stock ones. I can't figure out though what has been changed or modified. If you guys need any other pictures just tell me, I can grab them.
Thanks a bunch!
DosEquis82 is offline
post #2 of 6 Old 01-08-2015, 11:09 PM
Quoted: 11 Post(s)
Reputation Power: 57
Re: 03 954RR Suspension Reset
Looks stock to me. The adjuster in the top picture is your preload setting. Lowering dogbones usually have 3 holes or are adjustable. From the shape visible in the bottom picture is looks like stock dogbone. The triangle plates should have arrows on them that should point towards the bolt in the bottom of the shock.
SOLD: 03 CBR954
backdoc is offline
post #3 of 6 Old 01-09-2015, 12:43 AM Thread Starter
Is the dogbone a perfect triangle? Or is it uneven. And I'm guessing each notch from the furthest left is the setting on the preload? Thanks for the help
By the way.
post #4 of 6 Old 01-09-2015, 12:54 AM
Quoted: 11 Post(s)
By the way.
No its not a perfect triangle. The side running from the bolt in the swingarm to the shock should be the shortest. When lowering links are installed the triangle plates are rotated clockwise one hole to provide extra clearance for the lowering link. The left most notch at the top will be the softest and far right the stiffest for preload. The stock tool kit should have a spanner wrench that fits in the notches to adjust the spring preload.
SOLD: 03 CBR954
backdoc is offline
post #5 of 6 Old 01-10-2015, 2:55 PM Thread Starter
This is what my dog bones look like now, but I can no longer flat foot my bike which seems weird because I'm 6 feet tall. Can you tell my if this looks correct? The arrows point to the shock with the lettering facing out towards you.
post #6 of 6 Old 01-10-2015, 7:42 PM
Quoted: 11 Post(s)
That looks correct. I am 5'9" and when my bike was stock suspension I could barely touch with both feet. The 929 rear spring is stiffer than the 954 and would be better suited for most riders. The front suspension is what needs to be redone because its way too soft in stock form. Racetech gold valves and stiffer fork springs set up for your weight make a big difference in handling for a 954.
SOLD: 03 CBR954
backdoc is offline
02 954rr rear suspension solid. Help weien88 General Discussion 11 09-06-2013 12:53 AM
954rr triangle suspension linkage johnnyblade Honda FireBlade 0 07-06-2010 4:29 PM
Suspension Setting For 03' 954RR rotem_46 Honda FireBlade 10 08-12-2005 4:20 PM
954rr suspension setup Ray Honda FireBlade 7 11-26-2004 6:31 PM
Setting up Suspension on 954rr just_john Honda FireBlade 9 08-22-2003 2:48 AM
