lonely connectors - Honda Motorcycles - FireBlades.org
post #1 of 4 Old 01-11-2015, 5:01 PM Thread Starter
Reputation Power: 5
lonely connectors
Where do these connect? My blinkers don't work and my headlights don't work. Could these be the culprits? I picked up a revival project. These are the only two concerns I have right now
20150111_123746.jpg‎   20150111_123739.jpg‎   20150111_141627.jpg‎
aznpersuasion is offline
post #2 of 4 Old 01-11-2015, 6:59 PM Thread Starter
Reputation Power: 5
Re: lonely connectors
Also I tested my left rear blinker. It's an LED and does t he whole solid light instead of blink. Is this the typical case of I need an electonic flasher relay or something to that effect? And secondly the cluster seems fully functioning minus the backlight.
post #3 of 4 Old 01-11-2015, 8:18 PM
Quoted: 734 Post(s)
Reputation Power: 102
The first 2 are blinker connectors. They aren't connected because judging by the photo in your other thread you don't have any front signals. The third pic is the ground block. Open it up and make sure there's no corrosion in there. It doesn't connect to anything. Looks like your headlight connectors are connected. Have you checked the fuses?
IanDoohan is offline
post #4 of 4 Old 01-11-2015, 8:50 PM Thread Starter
Reputation Power: 5
I brie fly glanced at the fuses before I left. I'll doube check when I get home. I also grabbed a buddies multimeter to check for power. From the wiring diagram it looks like the cluster light uses the headlight relay. Maybe dead relay? Also noted that the light on the light switch doesn't illuminate. It sucks being at work not being able to test...
Just ordered cf13 electronic relay to hopefully get the blinkers working
OEM BLINKER CONNECTORS Jambard Electronics 1 09-01-2014 10:26 PM
Any one around the Portland/Clackamas area? Feeling lonely Jspooner09 General Discussion 0 08-11-2013 11:40 PM
ECU Connectors vnm02 Aftermarket Perfomance Parts Reviews 5 06-27-2012 3:25 PM
2008 cbr 1000rr OEM connectors wjdrake21 Honda FireBlade 4 02-11-2009 12:06 AM
929 Tailight Connectors Duke Honda FireBlade 0 04-17-2004 12:26 AM
