No wonder my bike was overheating... - Honda Motorcycles - FireBlades.org
post #1 of 11 Old 01-12-2015, 3:11 AM Thread Starter
Look what I found today. God knows how long it was like that. Bike was reaching high temps very quickly if I wasn't on the move.
Anyway I can fix this (weld) ? Or I'm going to have to pray I can find a used one for cheap; mighty putty perhaps ?
LeKoz is offline
post #2 of 11 Old 01-12-2015, 6:08 AM
Reputation Power: 9
Re: No wonder my bike was overheating...
Radiator shop should be able to braise that up. Its not under pressure there anyway
robdanjor is offline
post #3 of 11 Old 01-12-2015, 2:46 PM
Quoted: 732 Post(s)
Reputation Power: 102
Pretty sure that just sends low pressure expanded or "overflow" coolant to the catch can. Should be able to have fixed up without issue. Doubt that would send the system into overheating though. It's open to the catch can so having it open there would just let it dribble out there rather than get caught in the can. What it won't do is have the suction effect to pull back from the catch can to refill the system. So once it leaks out its gone. More likely that's the issue. Does it leak all over everything? You should see it dripping somewhere if the system is properly filled.
IanDoohan is offline
post #4 of 11 Old 01-12-2015, 4:21 PM Thread Starter
Actually taking the bike for the first time since I purchased it in August. Didn;t use it much. But it was an accidented bike the previous owner fixed. He was more in hurry to get it back on the road then anything. I didn't have any issues really other than it hitting 103 degrees pretty fast when stopped in traffic. No leaking either. Going to check coolant levels and examine the rad shortly
LeKoz is offline
post #5 of 11 Old 01-12-2015, 5:48 PM
Quoted: 120 Post(s)
Reputation Power: 198
What bike do you have LeKoz?
103C = 218F. If you're on any of the FI bikes, 929,954,1000, RC51, etc., it's no worries. That's a normal temp for them.
Did your fan kick on? I'm used to them kicking on at 219F and back off at 209F. On FI Hondas that is.
jondog9 is offline
post #6 of 11 Old 01-12-2015, 5:50 PM
Quoted: 120 Post(s)
I just looked up your stats and see you have a 03 954. Is this the same bike? If so - like I said above, you're not overheating at all.
jondog9 is offline
post #7 of 11 Old 01-12-2015, 6:44 PM Thread Starter
yup 954 it is.
Didn't know they get that hot! My other bikes, even the VFR was okay. The fan does kick in at 103*C (217*F) but temp continues to rise. Highest I've seen it go so far in traffic was 109*C (228*F) and I was in a little panic. Eventually got rolling and it dropped.
LeKoz is offline
post #8 of 11 Old 01-12-2015, 8:25 PM
Quoted: 120 Post(s)
Maybe someone can verify these numbers to apply to the 954, but I believe they do. I know it's correct for my RC51, but it's not an I-4.
You don't have to panic till somewhere after 235 -240F.
The temp light will come on at 251F, 122C, and the temp display numbers start to flash.
That means shut 'er off! I'm told by those who know, engine damage is likely at that temp.
You could try to burp the cooling system too, just in case you have an air bubble.
jondog9 is offline
post #9 of 11 Old 01-12-2015, 9:36 PM Thread Starter
I'll flush and clean the rad since since parts are off and check for further potential defaults. Thanks for the input it is much appreciated.
LeKoz is offline
post #10 of 11 Old 01-13-2015, 3:29 PM
macca9540's Avatar
Quoted: 50 Post(s)
Reputation Power: 270
Send a message via Skype™ to macca9540
From memory with my 954's jondog is close to the mark. They do run hot in traffic.
I started off with nothing and still have most of it left.
A closed mouth gathers no feet.
macca9540 is offline
post #11 of 11 Old 01-13-2015, 5:58 PM
Quoted: 29 Post(s)
230F sitting in traffic on a hot day with the fan running, seems to be normal operating temps for me.
The temp did go up a few degrees (was 223F) after I flushed the system last year, never could determine a reason for that though?
jdoni is offline
bike almost overheating at idle? number1dude General Discussion 4 11-21-2012 9:57 AM
Bike overheating lhazen91 Honda FireBlade 6 07-26-2011 12:23 AM
bike is overheating and oil is burning JordanCBRF3SJ Honda CBR 600 11 06-04-2010 5:46 PM
Overheating TheHeath Honda Naked Sportbikes 4 12-01-2009 6:49 PM
another overheating bike kiai Honda FireBlade 2 08-14-2008 5:56 PM
