929rr rattle at 1300 rpms - Honda Motorcycles - FireBlades.org
post #1 of 6 Old 01-26-2015, 12:46 PM Thread Starter
Hey guys. I am new to the forum and i have a 929rr. I have noticed a rattling noise coming from the left side of the bike, around the stator cover. It only does it at this certain rpm... above that and at idle once it has warmed up it does not do it. . It runs great other than that.. Not too sure what it could be. Help please
feagle is offline
post #2 of 6 Old 01-26-2015, 6:27 PM Thread Starter
Re: 929rr rattle at 1300 rpms
Another thing, the rattle is only when the bike is leaned over to the left. When you set it upright or to the right the rattle goes away. Oil level is fine
feagle is offline
post #3 of 6 Old 01-28-2015, 2:05 AM
Pull the stator cover and have a look, maybe the stator bolts have come loose.
post #4 of 6 Old 01-29-2015, 12:30 PM Thread Starter
Yeah, pulled it off yesterday and three of the bolts were backed out. Replaced them and added some loctite
feagle is offline
post #5 of 6 Old 07-04-2015, 3:09 PM
Hi Bladeracer, I think I have the same issue as Faegle.
Sorry, I'm a novice mechanic... Is the staor cover simply the engine cover on the left hand side? And, is it literally a cover? So, if I pop the bolts I don't want an explosion of bits and bobs! :-)
Paul
pauldodds is offline
post #6 of 6 Old 07-05-2015, 7:47 AM
Quoted: 29 Post(s)
Reputation Power: 12
It will come off without expoding, small bit of oil will leak, make sure drip tray under. It is magnetised, so you will need to prise it off, and make sure dowel is in place with cog correctly when refitting, new gasket will be needed, don't over tighten bolts, it will crack cover, don't ask me how i know lol.
Spaz is offline
White Smoke Rattle Rattle Knock Knock Cbr600rr Engine Rebuild Who in Perth ? Or DIY ? GIXXEN Honda CBR 600 9 05-10-2013 6:32 AM
1300 VTX needs help snakeg Honda Cruisers 13 08-26-2008 10:46 AM
hello I have an st 1300 markonotpolo Introductions 5 07-10-2007 11:38 PM
ST 1300 bikerpipes Honda CBR 600 1 05-03-2007 6:04 PM
Rattle Noise @9000 to 9500 rpms 2001 929rr General Discussion 2 07-01-2004 8:21 AM
