929 digital dash query - Honda Motorcycles - FireBlades.org
post #1 of 3 Old 02-01-2015, 11:52 AM Thread Starter
Hi all,
Joined here years back then lost login details so rejoined. I need advice from the great & good please!
I have mint 2000 929 which has been faultless so far. However, i recently stalled it on a cold morning on my gravel drive. Pressing the starter restarted the bike but killed the digital dash and rev counter. The backlight and warning lights still work.
All functions returned briefly later in the day, then disappeared again.
I have checked fuses,connections etc. All fine. I note that if I disconnect and reconnect the battery, the dash returns,until i start the bike, then they disappear again.
any thoughts? Like i say, the dash can be made to work, so the lcd is not dead.
really welcome any insight. Thanks,
Chris
Chris929 is offline
post #2 of 3 Old 02-05-2015, 11:46 PM
Re: 929 digital dash query
Did you try and disconnect the cluster from the connector on the back of the unit and reconnect it? It's possible that there is a loose connection and is getting poor connection from the vibrations.
2001 CBR 929RR Repsol replica
100% disabled veteran
mattitude is offline
post #3 of 3 Old 02-06-2015, 2:50 AM Thread Starter
Hi,
Yes, I went through all the connections, removed the dash etc. What I have subsequently found is that if I disconnect the battery and reconnect, the dash worked until I start the bike, then the dash disappears again.
My thoughts therefore, - must be battery. I've had the battery on charge for a few days. All seems fine now. I will take it out this weekend and give it a run to test (with a few starts/stops/restarts) to ensure it seems robust.
It would tie in with the idea that when I stalled on my driveway and restarted, the battery was low and the bike started but somehow the power is not sufficient to drive the dash. Odd, but looking like the case.
Thanks for your reply.
Chris929 is offline
Tags
digital display
Digital Dash jvx800 Honda FireBlade 1 12-02-2013 11:56 PM
Digital Dash for car or truck muds900RR For Sale 0 10-04-2010 2:44 PM
CBR 929 RRY Digital Dash Failure moohatchi Honda FireBlade 1 07-26-2008 2:33 PM
Aftermarket Digital Dash Psinic Electronics 3 11-23-2007 6:54 PM
Rc51 Digital dash readings? Help! timgo Honda RC51 5 02-09-2006 11:12 AM
