929 just wont play ball!!! - Honda Motorcycles - FireBlades.org
post #1 of 10 Old 02-02-2015, 4:07 PM Thread Starter
Hey guys, New to this forum, but been a blade owner since '08.
So yeah Hi
I have TWO of these 929 machines. One being a European model, the other a US import.
Now I know the US model doesn't have H.I.S.S.
The bike in question is the European model.
Charged battery, Fuel in tank.
Turn key on, kill switch in "run" position.
Fuel pump primes, H.I.S.S light goes out.
Press the starter button, and she just wont fire!
Any ideas? I've not dived into it yet, but the previous owner said he had issues with it on the past.
Bike has a PC3 fitted.
Harley Godzisz is offline
post #2 of 10 Old 02-02-2015, 7:31 PM
Quoted: 47 Post(s)
Reputation Power: 47
Re: 929 just wont play ball!!!
first thing i would suggest is to unhook the pc. its easy and its a game of elimination so easy stuff goes first. ive seen many times where that simple step fixes trouble bikes.
954Kevin is offline
post #3 of 10 Old 02-02-2015, 7:58 PM Thread Starter
Thanks for the reply Kevin.
Where exactly does the PC3 plug into on the 929? I've not had this bike apart yet.
post #4 of 10 Old 02-02-2015, 8:07 PM
Quoted: 47 Post(s)
you should be able to reverse hook-up(reverse hook-up???, yeah i made that up) your pc with this install guide. its really only a few plugs.
like i said i dunno if thats whats wrong with it or not but ive seen pc's do some screwy stuff to more than one bike. i mean they control a lot of aspects of your bikes running n with it being an easy thing to bypass just to be sure its not the problem its one of the first things i do if im trying to figure out a bike.
im pretty sure if the hiss is faulty the fp doesnt prime but dont quote me on that. i am in the u.s. so i dont have much in way of experience with that system. just what i read on here really.
does it have gas in the tank? lol
https://www.google.com/url?sa=t&rct=...,d.aWw&cad=rjt
EDIT hold on, that link is for a ignition module....
954Kevin is offline
post #5 of 10 Old 02-02-2015, 8:11 PM
Quoted: 47 Post(s)
here is the pc 3 install guide from their web site
http://www.powercommander.com/downlo...eng104-411.pdf
954Kevin is offline
post #6 of 10 Old 02-02-2015, 8:19 PM Thread Starter
Diamond geeza. I'll give it a go tomorrow evening. Failing that, I'm half tempted to whip off the CDI and loom from my US model as that doesn't have the H.I.S.S system.
post #7 of 10 Old 02-02-2015, 9:21 PM
Quoted: 47 Post(s)
take a look at the pc with the key on before you take it off just to check it has power. power or ground might have come loose n could be the problem.
954Kevin is offline
post #8 of 10 Old 02-03-2015, 12:49 PM Thread Starter
This was the first thing i did, It lit up and done it's led wave thing. twisting the throttle progresses the led's through the bar graph.
post #9 of 10 Old 02-16-2015, 8:29 AM
Reputation Power: 8
You should also check that the fuel pump hoses are in working order. IŽve had it happen to me a couple times that one of the hoses came off. The stock clamps holding the fuel lines in place are not that good. Easy to check, just open your fuel cap and prime it a couple times. YouŽll see if it shoots the gasoline from a wrong place inside the tank.
Zeri is offline
post #10 of 10 Old 02-24-2015, 11:15 PM
Does she crank?
Plugs probably spoiled. Rip the plugs out, give them a clean :-)
tkd_jase is offline
1988 ball of fun!!!!!!! blackduck Honda CBR400RR 3 09-08-2011 8:55 PM
Do not taunt Happy Fun Ball tigerblade Off-Topic 1 05-25-2006 11:39 PM
Keep the ball in the air! Chain Off-Topic 13 02-16-2006 6:28 PM
Be the ball Chain Off-Topic 1 09-08-2004 10:35 PM
a little 8 ball? showmethebombs Off-Topic 0 09-16-2003 3:10 PM
