needing help! - Honda Motorcycles - FireBlades.org
post #1 of 6 Old 02-02-2015, 8:32 PM Thread Starter
needing help!
I finally got my new ignition switch in the mail today. Slap it on the bike and still no fuel pump or anything. I can get the fuel pump to kick on running a jumper wire to the brown wire in the relay. And I can get the bike to crank jumping the starter button. That's all it will do really. I get just a neutral light on my dash. I'm at a loss.
01honda929rr is offline
post #2 of 6 Old 02-03-2015, 4:31 PM
Reputation Power: 7
Re: needing help!
The only help i can give on this issue is to check the wiring from the switch and the fuses.
Kevin
2001 Honda CBR 929rr Repsol Edition (Arielle)
https://www.fireblades.org/forums/hon...back-life.html
KGPrice is offline
post #3 of 6 Old 02-03-2015, 5:03 PM Thread Starter
Re: needing help!
Thank you. I was thinking the same thing. I get voltage on the brown wire going to the relay but not the pump. Relay is fine too. I'll give her a good look over again and get back with ya if I find anytjing
post #4 of 6 Old 02-04-2015, 10:44 PM
Re: needing help!
If the switch is aftermarket then you need to solder in the diode from your old switch.
post #5 of 6 Old 02-04-2015, 10:52 PM Thread Starter
Re: needing help!
The new one I bought is a OEM switch so it has the diode. Now that pink wire has 10v running through it instead of 13.
post #6 of 6 Old 02-28-2015, 2:48 PM Thread Starter
Re: needing help!
Just wanted to let everyone know I got the bike running !!! so excited !!! I replaced the wiring harness with a used one from eBay, new OEM ignition and killswtich and it fired rite up no problem!! Thanks for the help everyone
Needing Some Help!!!! Machinegun Honda FireBlade 4 11-16-2012 12:44 PM
New here and needing help briguy1917 Introductions 9 04-03-2011 2:58 PM
needing f4 parts splashofpaint Wanted 1 10-27-2010 12:34 PM
Needing some help here...about to go mad r3voltn1 General Discussion 29 05-20-2010 8:08 PM
Another new guy needing help..... mikew5174 Honda FireBlade 13 11-28-2006 10:43 AM
