02 cbr900 rr fuel pump not getting power - Honda Motorcycles - FireBlades.org
post #1 of 9 Old 02-13-2015, 3:27 PM Thread Starter
Ok guys i hav a 02 cbr900 rr. It runs greats. But is a project. I was trying to find the harnesses that go to the left control switch & the speedometer. They were tucked under the tank. So i undid the two front bolts & lifted it up just enough to get to them. Got them out & now thw fuel pump isn't getting power. So of course i tryed hooking it up to a new power & it worked. Wat could hav happened. . Any help thanks
messick53 is offline
post #2 of 9 Old 02-14-2015, 3:08 AM Thread Starter
Re: 02 cbr900 rr fuel pump not getting power
Any help. Y my pump is not getting power from the harness ????
post #3 of 9 Old 02-14-2015, 5:55 AM
Reputation Power: 5
Could be that the power cable has snapped within the sheath.
Have you had a look at the electrical schematic and had a jiggle of the wires to find which one is faulty or has a loose connector.
I'm guessing it this because it worked before you disturbed the wires.
Once you work out if its a broken wire or loose connector you will then need to joint the wire or repair the connector.
acemclynch is offline
post #4 of 9 Old 02-15-2015, 1:46 AM Thread Starter
I hav tryed to straight wire fuel pump it will turn on but the bike still wont crank. & iv messed with every wire on the bike & couldnt get anything to happen
post #5 of 9 Old 02-15-2015, 3:30 AM
Reputation Power: 5
Did the fuel pump turn on before or is this a new thing?
post #6 of 9 Old 02-15-2015, 1:07 PM Thread Starter
Yes everything worked fine untill i moved the tank. Iv messed with it for 2 day now & cant find out anything. Iv replaced every relay & checked all the fuses & grounds
post #7 of 9 Old 02-15-2015, 7:15 PM
Reputation Power: 5
Have you measured the voltage on the loom that plugs into the fuel pump when the bike ignition is on and the kill switch on?
Also recommend downloading the workshop manual and going through that.
post #8 of 9 Old 02-15-2015, 7:22 PM
Reputation Power: 5
Could it be the HISS immobiliser?
post #9 of 9 Old 02-15-2015, 7:22 PM
Reputation Power: 5
Or do the American bikes not have that
fuel pump not getting power nascar7613 Honda FireBlade 7 05-05-2014 12:39 PM
no fuel pump power kleenf4i Honda FireBlade 5 09-08-2012 6:45 PM
Want to buy cbr900 fuel pump 95erion For Sale 2 02-13-2012 11:51 PM
Help fuel pump not getting power frank88 General Discussion 8 03-23-2009 3:50 AM
Honda 929 No Power to Fuel Pump crxtacy Electronics 5 10-15-2007 11:31 AM
