1996 cbr900rr petcock fuel wont stop - Honda Motorcycles - FireBlades.org
post #1 of 6 Old 02-21-2015, 7:11 PM Thread Starter
as above guys , just bought a new petcock rebuild kit for the cbr900rr ,
but still having the issue of fuel still gravity fed , with or without the vaccum ,
no matter what fuel continues to flow ,
so is it rebuilt like this ,
spring / plastic disc / small diapraham , on inside
on outside large diapraham then outer face
sorry for the lack of pics at the minute guys
diffinking is offline
post #2 of 6 Old 02-21-2015, 8:05 PM
Quoted: 660 Post(s)
Reputation Power: 102
Re: 1996 cbr900rr petcock fuel wont stop
Here's what the manual says. I rebuilt mine last year but had to buy an entire new valve because the mechanical valve began to leak. Sometimes fuel can get past the valve when the diagram wears and loses it's elasticity.
IanDoohan is offline
post #3 of 6 Old 02-21-2015, 8:51 PM Thread Starter
cheers for that mate , when you say a mechanical leak was it allowing fuel to the carbs ? or leaking from around the outer casing
post #4 of 6 Old 02-21-2015, 8:55 PM Thread Starter
also , where does the little round black plastic piece go
post #5 of 6 Old 02-21-2015, 8:58 PM
Quoted: 660 Post(s)
Even when the motor was off and the fuel valve set to off the valve housing itself dripped. I think I changed it out before it became a bigger problem; leaking into the carbs/engine.
post #6 of 6 Old 02-21-2015, 9:12 PM
Quoted: 660 Post(s)
If you look at the pic from the manual the plastic disc is the seat against the diaphragm for the spring. It's tough to see.
98 RRW Fuel in Vacuum line to petcock? Bubbamcf Honda FireBlade 6 09-12-2014 9:09 AM
98 900RR Petcock fuel leak kornwaffle Honda FireBlade 4 07-30-2013 6:58 AM
fuel petcock hondafastbike Wanted 3 04-21-2010 10:13 PM
CBR900RR Fuel Petcock/Switch ('98) Erwin8r Honda FireBlade 2 05-08-2009 1:07 PM
900RR Fuel Petcock Position FerstlerSlim Honda FireBlade 6 03-06-2006 2:36 AM
