Whats this mean? - Honda Motorcycles - FireBlades.org
post #1 of 18 Old 02-26-2015, 10:31 PM Thread Starter
Reputation Power: 6
Whats this mean?
Whats up everyone! I'm trying to diagnose the red light and the f1 symbol that comes up. I know its all in the service manual but just wanted to check with you guys and see if you guys have encountered this specifically. What do you consider this? A single blink or no blink red light?
Bikes had them on since I purchased it so I wouldnt be able to tell anything different but seems to be running great.
This video shows what it does! Thanks in advance for any input!
File Type: mov trim.D7F5375B-C50F-4A88-A686-2E6D20102100.MOV‎ (7.84 MB, 22 views)
repo9809 is offline
post #2 of 18 Old 02-27-2015, 6:29 PM Thread Starter
Reputation Power: 6
Re: Whats this mean?
Anyone??????!!!
repo9809 is offline
post #3 of 18 Old 02-27-2015, 8:25 PM
Quoted: 47 Post(s)
Reputation Power: 47
i cant tell from the clip if its a 1 or not. you need to get under the seat n jump the diagnostic connector with a paper clip or a short wire with the bike off and then turn it to the on position n see how many blinks your getting. then get back with us. the connector is black, its under the driver seat on the right side if your sitting on the bike. it has 2 wires going into it n nothing hooked up to it. put the paper clip down in each side to complete the circuit. then turn the bike to on but dont start it. itll start blinking the codes. itll blink them in a loop over n over with a pause between loops.
if it is actually 1 blink go ahead and clear the memory and check your map sensor. its on the right side of the air box. it should have a vacuum line coming from it and a clip with wires. ive forgot to hook up my vacuum line myself after taking the air box off n it will throw the code. if its hooked up i would pull the clip n make sure its clean n no dirt or corrosion was present n plug it all back up. clear the codes n see if it comes back. if it still comes back make sure the far end of the vacuum hose coming off it is hooked up n doesnt have any leaks. if its all hooked up you might have a bad sensor or the wiring going to it is shorted out. most likely the vacuum hose is unhooked tho.
like i said tho its hard telling if its a 1 blink or not until you jump the diagnostic terminal under the seat.
also, just a heads up, if you upload your video clip to youtube n post the link here for the video instead more people will watch it. most people arent going to download stuff.
anyway, hope this help you out. if it turn out to be another code once you test it let us know.
954Kevin is offline
post #4 of 18 Old 02-27-2015, 9:44 PM
Quoted: 120 Post(s)
Reputation Power: 198
It's just too risky these days to download onto your device from a forum.
jondog9 is offline
post #5 of 18 Old 02-28-2015, 4:03 AM Thread Starter
Reputation Power: 6
For sure thanks man! I'll do that hopefully in the AM (snows suppose to be on its way)
And let you guys know. You really have to download it? I didnt know that.. I'll start posting them on youtube then with a link on here!
repo9809 is offline
post #6 of 18 Old 03-02-2015, 8:48 PM Thread Starter
Reputation Power: 6
I just jumped the connector and it looks like codes 11,34,35. Any suggestions?
Heres a link to the video I took jumping it!
repo9809 is offline
post #7 of 18 Old 03-02-2015, 10:22 PM
Quoted: 120 Post(s)
Your vid isn't long enough for me to get it...
Clear the codes from the memory.
Your manual tells you the procedure right before the actual list of codes.
Then restart the bike, or at least turn the ignition on to see if any codes remain.
If you get no indication of any codes when you turn on the ignition or get the bike running, take it for a ride to see if new codes set.
I say that because if you don't know the last time the codes were erased, then they may old stored codes that are not relevant now. If they are, they will come back.
I didn't take the time to look up those codes since you have a manual, but in some cases, the ECU will assign an acceptable value to override the code and the bike will seem to operate normally.
EDIT: I'm assuming you have a manual, did you mention in another thread that you have one?
jondog9 is offline
post #8 of 18 Old 03-02-2015, 11:37 PM Thread Starter
Reputation Power: 6
I've actually reset it already. Yea I have a manual but just wanted to see if anyone had suggestions before I start doing anything else.
repo9809 is offline
post #9 of 18 Old 03-03-2015, 11:27 PM Thread Starter
Reputation Power: 6
I checked and cleaned the speed sensor and reset. Got rid of the 11 and 35 codes but still throwing 34. I cant seem to find the servo motor on the thing.
repo9809 is offline
post #10 of 18 Old 03-03-2015, 11:37 PM
Quoted: 47 Post(s)
just follow the cables from the htev valve on the exhaust up to the servo motor. its on the left side
954Kevin is offline
post #11 of 18 Old 03-04-2015, 1:38 PM Thread Starter
Reputation Power: 6
Im not finding any cables? This is the left side under the tank where the servo motor is suppose to be according to the manual.
image.jpg‎
repo9809 is offline
post #12 of 18 Old 03-04-2015, 2:05 PM
Quoted: 2 Post(s)
Reputation Power: 37
Looks like the HTEV servo was removed, which would explain the code. Not a big issue, just the annoying FI light won't go off unless you do a "servo buddy".
The cables would attach where I have the exhaust sensor located for my Z-FM.
WIN_20140717_110208.JPG‎
Lobsta13 is offline
post #13 of 18 Old 03-04-2015, 2:15 PM
Quoted: 47 Post(s)
yep just looks like its been deleted. pretty common mod. might just check on ebay n search servo buddy. they are like 50$ there is also a write up on this site in the how to articles section that tells you how to build one with radio shack parts for like 10$
954Kevin is offline
post #14 of 18 Old 03-05-2015, 8:42 AM
Quoted: 2 Post(s)
The servos fail over time, as the plastic gears strip out pretty easily if the cables get stuck.
As Kevin said you can make a servo buddy easy enough if you have basic electronic skills or just buy one if you don't feel like trying it out. Search the forum for HTEV delete and you'll find it.
I left my light on and rolled with it.
Lobsta13 is offline
post #15 of 18 Old 03-06-2015, 1:06 AM Thread Starter
Reputation Power: 6
Yea i dont really care about the light being on, just want to make sure its not affecting the performance of the bike in any way.
repo9809 is offline
Whats up everyone! f3guy Introductions 5 03-09-2011 2:10 AM
whats up madmouse1 Introductions 4 03-13-2007 7:17 PM
whats up dunn_95_rr Introductions 16 04-19-2006 3:57 PM
Whats up? truff1 General Discussion 8 03-21-2006 2:33 AM
whats up KAWBOY69JR General Discussion 45 09-29-2005 9:19 PM
