929 indicators turn on delay - Honda Motorcycles - FireBlades.org
post #1 of 8 Old 03-14-2015, 5:05 PM Thread Starter
Quoted: 7 Post(s)
Reputation Power: 5
Apologies if this has been dealt with before.
My UK 01 plate 929 was fitted with replacement indicators when
I bought it. I donít have the originals.
There's a huge delay between me turning them
on and them starting to flash.
Anyone any ideas or suggestions?
TheGSL is offline
post #2 of 8 Old 03-15-2015, 9:15 AM
Reputation Power: 15
Re: 929 indicators turn on delay
Break out that voltmeter and start probing!
rudyrov is offline
post #3 of 8 Old 03-15-2015, 10:12 AM
Quoted: 120 Post(s)
Reputation Power: 198
Have you tried swapping in a known good relay?
jondog9 is offline
post #4 of 8 Old 03-16-2015, 2:55 AM
Reputation Power: 6
Hi, my bike started to do the same thing. I changed the relay first but it made no difference. It was actually the left hand switch gear that was knackered. I got a second hand switch gear off eBay and that fixed it. It might be worth spraying some wd40 into the indicator switch and see if it improves.
SconuT is offline
post #5 of 8 Old 03-16-2015, 11:49 AM
Quoted: 2 Post(s)
Reputation Power: 9
I had the same issue, I sprayed my switch out with Brake parts cleaner, and used some dielectric grease to lube everything up. It's smooth as butter now. I ended up doing the other side too (Start button and kill/run switch).
2001 929RR
1993 Kawasaki KLR 650
Pablo.gyds03 is offline
post #6 of 8 Old 03-16-2015, 6:39 PM Thread Starter
Quoted: 7 Post(s)
Reputation Power: 5
I'm starting to think I will try the wd40 in the switch first and see how that works out.
TheGSL is offline
post #7 of 8 Old 03-23-2015, 8:15 AM Thread Starter
Quoted: 7 Post(s)
Reputation Power: 5
Changed the rear indicators, and it is a lot better. Am gonna change the front ones, to hopefully improve it further. Badly fitted replacements I think are at least partially to blame.
TheGSL is offline
post #8 of 8 Old 02-08-2016, 2:58 PM Thread Starter
Quoted: 7 Post(s)
Reputation Power: 5
Just a little update to this thread, took the left hand switchgear apart yesterday, nothing dirty etc. looking about it inside. Just two philips head screws holding it onto the bars. Had a good look at it, removed all the old lube/grease, wiped it off with a cloth, some wd40, put it back together. Indicators come on immediately now. However, I think that there is some fatigue in the switch, where a ball bearing pushes the actual turn switch back, as it won't re-centre etc. when turned to the right now, has to be done manually. Still works okay to the left. It is nice just to have indicators that work immediately, I can live with it, hoping it will loosen up eventually. Definitely worth doing this if your indicators are playing up.
TheGSL is offline
turn signals delay activation (1998 CBR 900RR) c0ldfusi0nz Honda FireBlade 15 10-25-2013 8:22 PM
LED Indicators/Turn Signals Hicksi Honda CBR400RR 2 02-22-2012 2:40 PM
Headlights and Front turn indicators dicedreams2000 Honda FireBlade 1 08-05-2008 1:52 PM
Motrax LED turn indicators Fastrr Aftermarket Perfomance Parts Reviews 3 11-04-2007 2:29 AM
turn signals/indicators jrocket Honda FireBlade 8 07-26-2007 3:04 PM
