97 Cbr900rr service - Honda Motorcycles - FireBlades.org
post #1 of 4 Old 03-29-2015, 8:41 AM Thread Starter
97 Cbr900rr service
whats up guys this is my first post I bought a 900rr last summer put maybe 2500 miles on it ish and now its at about 18.5k miles. What Im wondering is at what point should i have the bike serviced? I called the local honda dealer and the first thing he said is it needs the valves adjusted right now. At what point do i need to have it serviced? the bike runs flawlessly.
thanks
fizelj is offline
post #2 of 4 Old 03-29-2015, 9:01 AM
Quoted: 665 Post(s)
Reputation Power: 102
Re: 97 Cbr900rr service
16k is the interval for checking the valve clearances. Typically they don't need any shims swapped out which is the high dollar charge in that service. So the dealer was right on with they're statement. You can let it go a couple K if you want, sometimes they'll get a little noisy or it will start to run crappy. Oil and filter should be dumped every 3k, that's also pretty typical. Coolant and brake fluid every 2 years, adjust and lube cables and check tire pressures and chain slack/lube after every ride. Pop your tank and check your air filter if you haven't since you bought it. Replace with OEM filter if dirty and plugs can get swapped out every year if you want. They're cheap enough. Check your brake pad thickness and that's about it in a nutshell.
IanDoohan is online now
post #3 of 4 Old 03-29-2015, 9:18 AM Thread Starter
Cool thanks for the information. If i let them go say another 1k miles is it going to hurt anything?
fizelj is offline
post #4 of 4 Old 03-29-2015, 10:24 AM
Quoted: 665 Post(s)
Nope.
1997-99 CBR900RR Service manual FMFWINGMAN Wanted 14 10-26-2012 4:17 PM
Best service manual to buy for cbr900rr 1998 paulybatz Honda FireBlade 13 05-09-2010 10:04 PM
CBR900RR-W Oil / Service Question. Jay300zx Honda FireBlade 0 06-03-2008 6:35 AM
