900 disk sizes? - Honda Motorcycles - FireBlades.org
post #1 of 8 Old 03-31-2015, 8:30 AM Thread Starter
Reputation Power: 19
900 disk sizes?
A friend with a 93 blade was wondering if he could use a better pair from a 96 blade, the black/yellow model. They are in good nick apparently but he can't measure them against his. They look the same to me although I believe the part numbers don't match. I'm guessing you people will know if they fit. Can any expert tell me? Incidently they look the same as what's on my 400.
davez is offline
post #2 of 8 Old 03-31-2015, 4:28 PM
Quoted: 656 Post(s)
Reputation Power: 102
Re: 900 disk sizes?
They have the same outer diameter at 296mm. The difference is the inside diameter and bolt hole spacing. The 93 is 62mm inside (hub) diameter, whereas the 95 and later are 58mm. The 93 rim uses a mechanical speedo drive on that rim, and the 95 and up use an electronic speed sensor not located on the wheel. They will not swap over.
IanDoohan is offline
post #3 of 8 Old 03-31-2015, 5:03 PM Thread Starter
Re: 900 disk sizes?
OK, thanks for the info Ian. Looks like its a no on those discs then.
Cheers
Dave
davez is offline
post #4 of 8 Old 03-31-2015, 5:47 PM
Quoted: 29 Post(s)
Reputation Power: 12
Re: 900 disk sizes?
I can reccomend Blackshadow, for aftermarket.
Spaz is offline
post #5 of 8 Old 03-31-2015, 5:49 PM
Quoted: 656 Post(s)
Re: 900 disk sizes?
Cheers
Dave
No problem Dave. I'm guessing the 96 disks were just in better condition?
post #6 of 8 Old 04-01-2015, 2:14 AM Thread Starter
Re: 900 disk sizes?
Yes they were in better condition than his higher milage discs. I will inform him of Spaz's recommendation as I recall they are in the UK, hopefully better than the Chinese type.
davez is offline
post #7 of 8 Old 04-01-2015, 2:36 AM
Quoted: 656 Post(s)
Re: 900 disk sizes?
Understood, good luck!
post #8 of 8 Old 04-01-2015, 2:30 PM
Quoted: 29 Post(s)
Re: 900 disk sizes?
Wales, but don't let that put you off
Spaz is offline
Used rear brake disk arinb12 Honda CBR400RR 4 09-08-2011 6:52 AM
Bad friction disk OEM zx12maniac Honda FireBlade 1 11-13-2010 10:35 AM
CBR 929 rear disk brake chris86_CBR Wanted 10 08-12-2010 11:04 AM
Cracked Disk smoothrideronli Off-Topic 5 10-13-2006 3:53 PM
Dvd Disk problems stegen Off-Topic 13 05-26-2003 5:16 AM
