98 CBR 900rr Issues - Honda Motorcycles - FireBlades.org
post #1 of 18 Old 04-09-2015, 10:18 PM Thread Starter
98 CBR 900rr Issues
New to the forum and just picked up a 98 900rr.
Things the bike needs now......
1: Rear brake lever mount is busted.... Will add pic
and would like to know the best place to pick one up.
2: No front turn signals. I'm not sure why but it looks like it had flush mounts at one time. The rear signals still work. Ill add pics so you can see. I would also like to know the best site to pick some up.
3. No tag lights at all. I thought about just buying a short LED strip and tapping into the running lights.
4: When at idle and deceleration I have a popping sound like It's running to rich or lean. It does have a Vance and Hines pipe but I'm not sure it was tuned at they had it installed. I'll add video after I upload to YouTube.
Thanks and all help is greatly appreciated.
pcbDezz is offline
post #2 of 18 Old 04-09-2015, 11:06 PM
Quoted: 47 Post(s)
Reputation Power: 47
Re: 98 CBR 900rr Issues
im not much of a carb guy so i wont throw guesses out about the popping. as far as thye parts you mentioned needing check ebay. there is a huge selection of flush mount signals. just look for a seller with plenty of good feedback and i usually sort by distance, nearest first to kinda cut thru some of the china sellers. not to say i wont buy china stuff or that most of them prob arent made there anyway but shipping is faster and should there be a problem its a bit easier to deal with a us seller imo. : ) im not 100% but i think when you put in led lights on these older bikes you gotta add some kind of flasher module or they will flash very fast. ive never added led where incandescent bulbs were so dont quote me on that. i dont think its anything major just a little box that goes in line when you install led blinkers.
its a little hard to tell exactly whats up with the brake master from the picture. is the whole rear set broken where the heal plate goes thru n bolts into the master? either way again check ebay for used parts. if nothing else you can get a set of these china rear sets for under 100$ and everyone ive seen or talked to says they are actually nice.
Black Rearset Foot Pegs Rear Set Honda CBR900RR CBR893RR CBR919RR 1994 1999 | eBay
http://www.ebay.com/itm/Honda-CBR900...bb8776&vxp=mtr
here is a used right rear set and it alone is about the same cost as the new aftermarket set from china. if it were me and my money id just buy the aftermarket. they are adjustable so kind of an upgrade.
http://www.ebay.com/itm/98-99-HONDA-...7724a6&vxp=mtr
someone on the site might have a set they would let go of as well.
or if your wanting a new oem part check ron ayers or partzilla's web site. they have parts fiche you just look up your part number from the diagram n can order from them. be ready with the wallet tho. : )
954Kevin is offline
post #3 of 18 Old 04-09-2015, 11:39 PM Thread Starter
Vid of the popping..
pcbDezz is offline
post #4 of 18 Old 04-09-2015, 11:41 PM Thread Starter
Honda CBR900RR Rear Set 1998 1999 Pro Tek Rearset CBR 900RR CBR 900RR | eBay
98 99 Honda CBR900RR Right Rearset Rear Set Driver Foot Peg Rest Stop | eBay
Thanks for the links and feedback.
pcbDezz is offline
post #5 of 18 Old 04-10-2015, 1:24 AM
Quoted: 665 Post(s)
Reputation Power: 102
Kevin gave you some great information. The OEM footpeg on eBay is a good price for what's included. I'll try to shed some light on the popping.
A well tuned 900 with a pipe AND jet kit should idle smoothly with no popping. I've never heard a 900 pop at idle like that. I'm gonna say that there is one or more cylinders that is running very lean. Almost like a really bad misfire. I also noticed the revs tended to "hang up" a bit when you blipped the throttle. A properly running 9 should sound like this:
Now, to help you out with your problem, I would recommend removing the carbs, take an inventory of the main and slow jet sizes, vacuum needle position, and fuel mixture screw turns out from lightly seated. Once that is done take the carbs COMPLETELY apart and clean them. Make an initial fuel screw adjustment to 2.5 turns out from lightly seated. Once properly cleaned and put back in the bike have them synced. I would recommend doing this yourself, and buying a manual. I've been working on 900's for the better part of 23 years. They are one of the best running bikes when properly set up. It's not rocket science, but carbs can be daunting the first time you tear into them. I have tons of carb photos I can post for reference if you need them. But if it were my bike the carbs would have already been out and on the bench in the time it took me to type this. Whether you do it or a shop does it, it needs to be done. Good luck, welcome to the forum, welcome back to motorcycles, and congrats on the new to you 900RRW.
One more thing, I don't know if you know, but the first picture has the bike sitting really low. Did you know the triple clamp is like 2" lower than stock? Looks like the rear as well. FYI only really.
Last edited by IanDoohan; 04-10-2015 at 1:26 AM. Reason: Added bit about lowering.
IanDoohan is offline
post #6 of 18 Old 04-15-2015, 9:14 PM Thread Starter
Well I had to pull to carbs. I could ride about 5 miles and it would lose power and die. It would take a minute or two before it would start up.
Before the bike was popping at idle and deceleration. I pulled the carbs and checked the air/fuel mixture and it seemed way out. It was 3 1/2-4 1/2 turns out. I set them all at 2 turns out and the idle popping has completely stopped. The deceleration popping is so small that you can barely tell. I'll pull them again this week and see if i can get the mixture perfect.
As for the tag light issue... I just bought a cheap 4 inch LED strip from autozone and wired it in. Seems to work great. I will be ordering a rearset tomorrow. I'm still trying to decided on the Mirrors with turn signals built in or flush mounts. I made even do both just so that people can see me better.
pcbDezz is offline
post #7 of 18 Old 04-15-2015, 11:35 PM Thread Starter
After changing the A/F mixture.
I think I need another exhaust because I like the way IAN bike sounds.
pcbDezz is offline
post #8 of 18 Old 04-16-2015, 12:04 AM
Quoted: 665 Post(s)
Well that does sound a helluva lot better, but seems to only be running on 3 cylinders. Once it's warmed up spray a small amount of water on each header pipe. It should bubble and burn off immediately. Make sure all cylinders/header pipes do it. If one or more don't, and the water runs down the pipe than those cylinders aren't firing properly.
And my sound is all Erion racing, nice rich throaty sound. Thanks for the shout out
post #9 of 18 Old 04-16-2015, 1:15 AM Thread Starter
I looked at some of your pics from your build thread and notice i have a small black
box??? missing on the hose I'm touching with the needle nose. Could that be causing some of the issues?
pcbDezz is offline
post #10 of 18 Old 04-16-2015, 1:27 AM
Quoted: 665 Post(s)
No, the box is just a small housing for a thin foam air filter. That vent tube allows the slides to raise and lower. It just filters the small amount of air coming and going from that tube.
post #11 of 18 Old 04-16-2015, 2:03 AM Thread Starter
Found a rearset on eBay and it should be here by Monday I hope.
pcbDezz is offline
post #12 of 18 Old 04-16-2015, 2:31 PM Thread Starter
OK..... Fired up bike and let it warm up for about 45 seconds. I sprayed water on all four exhaust pipes and the one on the far left was still cold. I have read to check the plug and see if it's firing and to spray starter fluid in that carb to see if it gets hot. What other things can I do to diagnose the dead cylinder?
pcbDezz is offline
post #13 of 18 Old 04-16-2015, 4:44 PM
Quoted: 665 Post(s)
Well, you've already identified the dead cylinder so good job on that!
Yes, see if starter fluid will initiate a burn, just be careful while spraying. If the fluid ignites and the cylinder comes back to life it's a fuel issue on that particular carb. If it doesn't ignite then you have a spark/possible compression problem. Pull the plug and test to see if it sparks by grounding the electrode on the motor or frame and hit the start button. If it sparks then it's an cylinder/valve issue. Do you have access to a compression tester?
post #14 of 18 Old 04-16-2015, 5:33 PM Thread Starter
Sprayed fluid...... Nothing
Checked spark..... It has spark but I was thinking it should have been more powerful. It's just a faint spark that barely even shocked me.
Changed plus to see if that would help and it didn't.
Maybe a coil issue???
I had to put her back together because of no garage and it looks like rain.
UGH......
pcbDezz is offline
post #15 of 18 Old 04-16-2015, 6:20 PM Thread Starter
Tried again with the starter fluid this time with the gas tank still on the bike so I could keep it running.... The pipe only got a little warm but the engine temp was 179. i'm guessing it was only warm because it's so close to the other pipe.
pcbDezz is offline
98 CBR 900RR Issues the_cuda_guy Honda FireBlade 4 06-12-2014 8:27 PM
93 900rr Engine issues tripwire Honda FireBlade 6 10-22-2013 3:34 PM
'96 900RR Battery Issues Gearshard General Discussion 3 09-14-2011 1:15 AM
99 900RR Electrical Issues. cool465 General Discussion 19 05-31-2010 7:43 PM
98 900rr having some electrical issues. Soul Honda FireBlade 15 03-21-2007 10:30 PM
