Dash not working properly - Honda Motorcycles - FireBlades.org
post #1 of 1 Old 08-15-2015, 12:04 AM Thread Starter
Quoted: 4 Post(s)
I was riding and my bike lost power, gained power, lost power again and died out.. So here is what I have found out. Before I begin I would like to put everything on the tabloe about the bike. 03 954, aftermarket HID hooked to running beam, stereo system directly to battery, LED kit hooked to battery.
After tearing down my bike and replacing the dead battery I noticed my dash no longer illuminated. The neutral light, high beam and turn signals lit, but the tach does not move, illuminate and the speedo did not work. After a closer investigation I noticed the HID kit was burnt as well as my starter solenoid melting almost like a bat stator connector. The fuel pump kicks in but I have nothing. So I swapped wiring harnesses. I swapped every harness just in case you are wondering. I replaced the tip over switch which I found to be fried My turn signals on the dash illuminate but do not flash. My turn signals are in working condition and they are LED with resistors installed.
I purchased another CDI to see if that were the issue.. Same problem still. I checked all my fuses.Everything seems ok. Brake lights and running lights function. When the bike is allowed to prime, the bike flashes code 19. But it flashes this code without jumping the wires.. I am at a loss... Does anyone have any suggestions?
Overall problem is the dash is not working properly.. Can the dash be tested. Happy I am building another 954... got alot of spare parts..
DDMGraphix1 is offline
Motodynamics LED Integrated Tailight License Plate Lights Not Working Properly cal2050 Electronics 3 06-09-2011 11:10 PM
NC29 not working properly especially when warm jason.d Honda CBR400RR 3 08-12-2010 2:21 AM
CBR 600 F2 Choke not working properly? Matroy Honda CBR 600 3 06-28-2010 4:43 PM
ssems like pcII is not working properly JamesEarl15 Honda FireBlade 18 05-13-2005 9:21 PM
