99 900rr carb splitting help - Honda Motorcycles - FireBlades.org
post #1 of 14 Old 12-28-2015, 7:14 PM Thread Starter
Reputation Power: 15
Hey all
I know theres been a few carbie posts .about leaks ..flooding
Just need some help from you who have separated the carbs
I have a manual butino step by step ..I have taken of the chock enrichment slider
Undone the two carby body bolts.that hold them all together
Just need some help on how to separate them .as pulled twisted nothing
I know in the manual says ..remove spring dowells but don't show how to get the springs of or where it splits at the center of 1/2 2/4 . Also these are the carbies on my 99 cheers also bike had fuel in motor as petcock.was.leaking out of the vacum side .
20151229_095149.jpg‎   20151229_095158.jpg‎   20151229_095308.jpg‎
fireblade90096 is offline
post #2 of 14 Old 12-28-2015, 7:43 PM
Quoted: 709 Post(s)
Reputation Power: 102
Re: 99 900rr carb splitting help
Look at my Cafe thread in my signature. Tons of photos on my carb dissasembly. But as far as splitting them, there are 2 rods that run the length of the 4 carbs. You'll have to pull them out before you can split them as there are dowel pins as well. Just be careful, as when you finally get them apart the springs will fly everywhere. Here's a pic:
IanDoohan is online now
post #3 of 14 Old 12-28-2015, 7:50 PM Thread Starter
Thanks Ian
That was the post I was looking for ..have the two rods of and the cock slider of .just couldn't see how they come apart ..as the manual dont do a step by step .just say what to remove ..and only numered the parts ..cheers will have a look at the above mentioned post
post #4 of 14 Old 12-28-2015, 8:08 PM
Quoted: 709 Post(s)
Originally Posted by fireblade90096 View Post
Thanks Ian
No worries, I have more. But that should get you going
post #5 of 14 Old 12-28-2015, 8:31 PM Thread Starter
Hey Ian
You did a great job on that build
Hey can you tell me if I have to disconnect anything between 1/2 @3/4 arbs to split them
As still cant get them apart ...should they just pull apart??? ..or a.spring needs to be unhooked cheers
post #6 of 14 Old 12-28-2015, 9:18 PM
Quoted: 709 Post(s)
Hey Ian
Nothing needs to be removed as far as springs go, they will just come off. It's probably the dowels that are seized together. If you have all the other rubber parts disconnected give it a little heat where the dowels are.
post #7 of 14 Old 01-01-2016, 12:43 AM Thread Starter
Thanks for ya advice cheers
Gunna replace petcock as its leaking ..so wondering if 96 97 98 rr petcock is the same as the 99
As a few on ebay ..bike shop is asking $230ish thought wt ...and rebuild kit is around $60 to get here to ozz ..anyway cheers again for all the info
post #8 of 14 Old 01-01-2016, 5:16 AM
Quoted: 709 Post(s)
Yep, 96 RRT - 99 RRX will all work.
post #9 of 14 Old 01-07-2016, 2:02 AM Thread Starter
Hey all ok went to fleabay to order a petcock..sent the seller a message asking if 96/97/98 petcock is compatible with my 99 got a reply saying no wont fit as I wanted to be sure ..as fighting with dealer for refund here in oz..anyway has anyone fitted a earlier mod petcock to your bike .just want to make sure b4 I order of ebay and not waste another $150ish ...cheers
post #10 of 14 Old 01-07-2016, 9:46 AM
Quoted: 709 Post(s)
Sorry FB90096, but the Ebay seller is WRONG. I had a vacuum operated on my RRP (93) SC28. That fuel tank was a different shape than the SC33 tanks, as well as the outlet being a bit different (it shortened the amount of reserve available), but the petcock still threaded on and operated perfectly.
The SC33 tanks as I said before are all the same 96-99, and used the same fuel valve for all those years. Also Partzilla, when choosing the petcock for the 97, lists it as the same available part number for 96-99.
The earlier 92-95 petcocks will work on yours as well, but as stated the reserve may actually be a bit MORE and you'll be switching to reserve sooner than you would with the proper petcock. The copper tube that the filter screen connects to is longer I believe on the older bikes because of the larger shape of the fuel tank.
The bottom line here is don't always trust what fleabayers say.
post #11 of 14 Old 01-07-2016, 8:31 PM Thread Starter
Hey ian .cheers for all the help and advise will order the 97 one now ..as rang more parts shops here in oz ..and if they can get one ..start at $350 to $230 .or $80 from usa on ebay cheers ..for all the help on the carbies and petcock issuse ...by the way got the carbs apart .as said a little heat helps .. and seals replaced on fuel joints. .seen local shop wanted $150 an hr quoted 3 hrs wtf..... did it in 1- 1/2 ....hrs off pull apart and refit to bike ..sorry for rambling cheers your a bloody legend Ian
post #12 of 14 Old 01-09-2016, 3:07 AM
Quoted: 709 Post(s)
Maybe a legend in my own mind. Glad you got the bank split, and good luck with the petcock hunt, Oz prices are HIGH!
post #13 of 14 Old 01-10-2016, 9:38 PM Thread Starter
Yes the prices here are a rip of ..thats what price gouging is all about out here
Greed .... anyway I have decided to jb weild it .turned it into a gravity feed .so will keep an eye on it over the next few hrs ...petcock on tank .vacum line on petcock and motor blocked of .new seals to air and carbies t sections...So fingers crossed will be all good .So thanks for all the input ...cheers
post #14 of 14 Old 04-04-2016, 5:02 AM Thread Starter
Just a follow up
Did the jenweild works a treat no leaks anywhere gravity feed working great
So ordered new fuel.cock.err put it on leakes again.. So back to old tap. Tomorrow also seemed.to.crack better mid range on gravity feed. Than the vacum feed line.. Maybe just in my head but ive neva been right up there lmao cheers for.all.the help
900RR carb o-rings? wotan Honda FireBlade 8 11-20-2015 3:57 AM
99 900RR carb issue. IRISH MIKE Honda FireBlade 6 10-02-2012 9:04 AM
CBR 900RR Carb Sync Eno900RR Honda FireBlade 5 02-02-2012 7:56 PM
95 CBR 900RR--WHERE CAN I GET A CARB REBUILD KIT? Busted9R Honda FireBlade 1 12-29-2009 4:51 PM
carb removal 900rr JohnnyInsano Honda FireBlade 1 02-05-2006 9:45 PM
