Temp gauge on tach 954 - Honda Motorcycles - FireBlades.org
post #1 of 3 Old 01-19-2016, 1:32 AM Thread Starter
Hi I took off my side panels to do oil change. After fairings put back my temp gauge on tachometer not registering. it did work prior. Can someone help. Thankyou... i have 2003 954 rr..
Rob954 is offline
post #2 of 3 Old 01-19-2016, 3:04 AM
Quoted: 48 Post(s)
Reputation Power: 48
Re: Temp gauge on tach 954
id start by checking the wires going to the engine coolant sensor(ect) it located near the back of the block where all the coolant hoses are.
it sounds like youve jiggled a wire loose or possibly a short somewhere. id pull the fairings off and start by unhooking the ect n inspecting the connector, clean it if its dirty. they make special electrical connection cleaners that can be found at auto parts stores. it comes in an aerosol can. then id put some dielectric grease on the connector n hook it back up.
it could be any one of the connectors in the harness from the front to the back so do the same for all of them in the wiring harness until you hopefully find the one thats not quite connected or dirty. you prob bumped one of them taking the fairing off n putting them on. itll be a bit of a pita but mostly just kinda time consuming going thru the connections n doing a little maintenance.
if that doesnt solve your problem id suggest downloading or buying the service manual. it can be easily found online. it has trouble shooting guides to help you find the problem. id bet its just like i said tho, a loose or dirty connection somewhere that was just barely hangin on till you bumped it doing the oil change.
heres a pic f the ect;
https://www.fireblades.org/forums/att...etc-sensor.jpg
954Kevin is offline
post #3 of 3 Old 01-19-2016, 1:35 PM Thread Starter
Thankyou much Kevin.. Very helpful. I will tackle this this weekend.
cheers.
Rob954 is offline
Temp gauge Andianne Honda CBR400RR 11 12-01-2013 4:22 AM
better temp gauge slothman Honda FireBlade 4 07-19-2012 10:50 PM
Foam surrounding tach and temp gage on 900RR? vtecpwr4 Honda FireBlade 3 06-30-2009 8:59 AM
Temp. Gauge question magic Honda FireBlade 5 08-13-2008 10:59 AM
Temp gauge reading 268 fshrmn76 Honda CBR 600 4 05-26-2008 2:18 PM
