Bought a Rough 98 - Honda Motorcycles - FireBlades.org
post #1 of 90 Old 02-16-2016, 1:16 PM Thread Starter
Quoted: 4 Post(s)
Reputation Power: 5
Bought a Rough 98
I picked up a 98 900RR last night. The plastics are pretty rough, but it runs and rides fine. I paid 1300 for it and a 94 parts bike, which is just a frame, engine, and swingarm. Missing the front wheel and forks. The engine feels very strong, plenty of power, and no strange noises. 33k miles.
It was cheap because there is a crack somewhere around the stator cover. Not sure if it's the cover or the case. The previous owner slathered all kinds of sealant around it, and I haven't torn it apart yet. It leaks oil pretty steadily.
What needs fixing:
1. Headlight alignment is way off, I think the fairing stay is bent because the whole nose is shifted to the left
2. Cracked case/cover
3. Rear tire needs replacing, chain and sprockets too.
4. The tail is cobbled together and needs some work. Looks like it might be a conversion? Somebody has cut it under the seat and bolted it back together.
5. Plastic repair or replacement.
6. Mirror is missing, rear brake lever needs to be replaced.
So, do you guys commonly see cases cracked? If so, where is the damage at usually? I've read about it on the 929 bikes, but not so much the 919.
Also, the speedo doesn't work, but everything else does. Is this a digital gauge with a sensor, or does it have a cable?
Atimm693 is offline
post #2 of 90 Old 02-16-2016, 2:49 PM
Gunk's Avatar
Quoted: 506 Post(s)
Reputation Power: 24
Re: Bought a Rough 98
Looks very much like the 1994 893 I bought last year, very similar condition, mine also only had one mirror!
Also like yours, mine had been down the road fairly hard, the nose and clocks were smashed and the generator cover was badly grazed. Fortunately it's oil tight and most of the damage was superficial, but expensive!
Gunk is offline
post #3 of 90 Old 02-16-2016, 2:50 PM
Gunk's Avatar
Quoted: 506 Post(s)
Now looks like this....
So keep us updated with your progress, we love a project!
Gunk is offline
post #4 of 90 Old 02-16-2016, 3:06 PM
Quoted: 58 Post(s)
Reminds me of the ugly duckling story...
Sabotage is offline
post #5 of 90 Old 02-16-2016, 3:57 PM
Quoted: 733 Post(s)
Reputation Power: 102
to the site.
Something like this on the left side most likely. I just had mine done this past fall, haven't gotten it buttoned up yet though.
The speedo sensor is electric, and the sensor is behind the starter on the top of the tranny case.
Looks like you have a project here start yourself a REbuild thread and let the fun begin!
IanDoohan is online now
post #6 of 90 Old 02-16-2016, 6:34 PM Thread Starter
Quoted: 4 Post(s)
Reputation Power: 5
Thank you all. I will did into it in a little while.
Originally Posted by IanDoohan View Post
to the site.
Sweet, thanks.
Atimm693 is offline
post #7 of 90 Old 02-16-2016, 8:02 PM Thread Starter
Quoted: 4 Post(s)
Reputation Power: 5
Well, I tore it all apart, and the damage is pretty bad. Broken in two places, and the pieces were not there. Looks like the previous owner used figerglass resin to seal it back up, which didn't work.
I have old cases laying around that I could probably cut and make new pieces out of, but I just don't know how easily it could be welded. I ordered a flywheel puller, and will drop the engine pretty soon.
What is the big allen bolt under the flywheel is for?
Atimm693 is offline
post #8 of 90 Old 02-16-2016, 8:30 PM
Quoted: 733 Post(s)
Oh Sh!t that totally sucks. I didn't have the piece for mine either. The area was cleaned up, and a doner CRF450 case piece was fabricated to fit. You could do same with the spare cases you have. The Allen is to block off the main. Oil galley. Pretty sure it's got a copper washer behind it and can come out.
post #9 of 90 Old 02-16-2016, 8:53 PM Thread Starter
Quoted: 4 Post(s)
Reputation Power: 5
Good to know, since it will probably have to come out to be welded.
I have two cases from an old Suzuki dirt bike that I'm not going to do anything with, so once the engine is out, I will look for cracks and trace out some pieces. These are aluminum, not magnesium right?
The bottom one will be especially tricky because of the curve and bolt hole.
Atimm693 is offline
post #10 of 90 Old 02-16-2016, 8:54 PM
Quoted: 733 Post(s)
Yes, aluminum.
post #11 of 90 Old 02-17-2016, 5:24 AM
Gunk's Avatar
Quoted: 506 Post(s)
That's worse than it looks because of all the crap smeared over the damage. With a donor case as Ian has demonstrated with his, that could be repaired.
In fact Ian's was worse because he had lost one of the threaded lugs.
Gunk is offline
post #12 of 90 Old 02-17-2016, 7:59 PM Thread Starter
Quoted: 4 Post(s)
Reputation Power: 5
It will be difficult to weld for sure, because both areas need to have a threaded boss for a bolt, but I found a shop that seems pretty optimistic about it.
Going to start the process of dropping the engine out now.
Atimm693 is offline
post #13 of 90 Old 02-17-2016, 11:38 PM
Quoted: 733 Post(s)
My cover was totally destroyed by the fall, so I had to get a replacement so the welder could line up the threads properly. When it originally broke, half the threads were still there. We completely cut them out to refit the new piece to include them.
I also had it welded while it was in the frame, in case you don't want to take it out.
Last edited by IanDoohan; 02-17-2016 at 11:40 PM. Reason: Added the part about leaving it in the frame.
post #14 of 90 Old 02-18-2016, 12:49 PM Thread Starter
Quoted: 4 Post(s)
Reputation Power: 5
Thanks for the pics, mine is broken in the same area. The shop I spoke with is going to fill the broken areas, then build up bosses that I can drill and tap for the stator bolts.
I pulled the engine out last night. I've made arrangements to bring it in tomorrow morning. So, as they say, good lord willing and the creek don't rise, I'll be going back together tomorrow night.
Atimm693 is offline
post #15 of 90 Old 02-18-2016, 2:07 PM
Quoted: 733 Post(s)
No problem, I hope it all works out for you. Looking forward to your updates
CBR 954 Rough idle, and bike is rough until 3000 RPM's Tree954rr General Discussion 2 07-20-2015 4:37 PM
rough idle netromcbr Honda FireBlade 6 05-30-2013 10:19 AM
rough under 3000 rpm DOBSIN General Discussion 4 03-25-2013 2:25 AM
954RR rough low-end not fpr jared.malcolm Honda FireBlade 10 07-01-2011 12:05 PM
rough sound kiai General Discussion 4 09-18-2007 12:36 PM
