Sato Rearsets with GP shifting - Honda Motorcycles - FireBlades.org
post #1 of 8 Old 03-29-2004, 11:21 AM Thread Starter
Administrator
Red Rider's Avatar
Reputation Power: 47
Anybody with a 929 and Sato's with GP (reverse) shifting have a pic of their set up? I just switched mine to GP and I'm not sure what angle to set the gearshift lever. I'm also wondering if I have the gearshift arm and the adjustment rod set up right.
Red Rider is offline
post #2 of 8 Old 03-29-2004, 1:07 PM
nedro's Avatar
Reputation Power: 27
Re: Sato Rearsets with GP shifting
The arm from Sato that goes on the shifter shaft should be at a 90 degree angle to the link that goes to the foot shifter while in a stationary position.
Ride Red
nedro is offline
post #3 of 8 Old 03-29-2004, 1:35 PM
The arm and the tab that hangs off the shifter should be as close to parallel as possible.
luvtolean is offline
post #4 of 8 Old 03-29-2004, 2:42 PM
nedro's Avatar
LTL's right!
Ride Red
nedro is offline
post #5 of 8 Old 03-29-2004, 2:42 PM Thread Starter
Administrator
Red Rider's Avatar
90 degrees to the link, but should the Sato arm be vertical (12 o'clock position)?
If I do that than the arm that connects to the shifter shaft won't be vertical (12 o'clock). Is that all right?
Dummy me pulled everything off without checking the relative positions of all the components first. Thanks for the help guys...
post #6 of 8 Old 03-29-2004, 3:32 PM
nedro's Avatar
It doesn't need to be at 12 O'clock. In fact, it probably won't be if done correctly.
Ride Red
nedro is offline
post #7 of 8 Old 03-29-2004, 3:51 PM Thread Starter
Administrator
Red Rider's Avatar
That's what I was wondering. Thanks!
post #8 of 8 Old 03-30-2004, 11:09 AM Thread Starter
Administrator
Red Rider's Avatar
Found a pic on the Sato site. Their GP setup definitely doesn't have the shift lever and the connecting rod parallel. Sato GP shift
Okay, got an M4 coming, Sato rear set parts, and a PCIII... Erwin8r Honda FireBlade 7 01-28-2004 9:20 PM
Quick question about the Sato rearsets 3cRider Honda FireBlade 1 01-18-2004 2:40 PM
Need advice about rearsets Schwaberts Honda FireBlade 4 01-18-2004 9:44 AM
Any advice for installing SATO rearsets HyrePower Honda FireBlade 4 12-13-2003 2:25 PM
