'95 900RR - Sagging Turn Signals - Honda Motorcycles - FireBlades.org
post #1 of 7 Old 05-31-2016, 11:32 PM Thread Starter
Looking for any tricks or suggestions on sagging turn signals. I'm guessing after 21 years the rubber has shrunk a bit and now they're sagging and lose.
The nuts are tight. Has anybody used any spacers or other tricks to snug up the turn signals? I'm guessing OEM turn signas are out there as plan B.
OB
Old_Bourbon is offline
post #2 of 7 Old 06-01-2016, 12:15 AM
Re: '95 900RR - Sagging Turn Signals
This is survivor meguyveer speaking. I have sagging, cracking, used to have a boner kind of stance, now it's in a viagara stance... Amazing Goop glue.
As you bend the cracks open, this is first round is to push as much in with fingers and work fast. Next is to cut a coat hanger wire or welding rod, having a larger diameter is choice, you cut to length, straighten the winker, lay the rod down the center (under the winker) so it looks clean from the top, run a bead down the rod laying on the winker. Roll the rod so it covers under and position the rod and let sink and setup.
Very workable stuff once you test things with it. For example, the push in and the rubbing off is see how that works is the tiny filler was enough that oozed out but stayed in meaning. Nasty stuff once dried. When you look up that goop brand name, see the tv, bowling ball, brick, swinging off some crane lifting it, believe it!
Catch22 is offline
post #3 of 7 Old 06-01-2016, 5:36 AM
Quoted: 159 Post(s)
Reputation Power: 122
OB
OB, and glad to hear the nuts are still tight, I would hate to hear they were splashing down in the toilet water. As far as the sagging goes, I don't have OEM signals so I'll ask, could you swap the left for the right and vice- versa, if I remember correctly the only different between the 2 is the color of the wiring. Maybe some 900RR owner will shed some light, Ian? Then instead of sagging they would look like morning wood. Your bike will feel 21 again! Oh, wait, it is 21. Remember, erections lasting more than 4 hours require medical attention, thank God for hot young nurses.
BTW, if you insist on OEM and really want it to look new again, $128 at Ron Ayers will get you 4 new OEM stays, ouch! Aftermarket.
I think your talking about item #15, right?
http://www.ronayers.com/oemparts/a/h...c9/turn-signal
fj1200rj is offline
post #4 of 7 Old 06-01-2016, 9:17 AM
$15 buys cheap aftermarket turn signals, and they don't stick out like skyscraper clearance lights. Why not upgrade to LED for $30? DMP Short Arrow LED Turn Signal - Motorcycle Superstore You'll have to add resistance or a relay to make them flash at the proper rate.
1926 is offline
post #5 of 7 Old 06-01-2016, 5:45 PM
Gunk's Avatar
Quoted: 496 Post(s)
Reputation Power: 24
I've got the same problem with original indicators on my 1994 Blade, they sag, Bob around when riding and basically drive me insane!
I've stripped them, tightened them, even packed them out with shims and they still sag and Bob around, only solution is to remove them and fit smaller, lighter mini indicators. I've found some on eBay that are still square but much smaller.
Gunk is online now
post #6 of 7 Old 06-02-2016, 1:12 PM Thread Starter
Thanks gents
Yah they are big and aftermarket is an option however i was trying to keep it all stock. Looks like i just deal with it or go aftermarket. May try the glue trick - I wish somebody with a CNC could make me a set of aluminum ones!
post #7 of 7 Old 06-02-2016, 3:06 PM
Quoted: 696 Post(s)
Reputation Power: 102
The design incorporates a sort of "break away" feature. They are giant, floppy, and ugly but they serve their purpose VERY WELL. If you had similarly sized pods on the there with a completely rigid mount, a tip over would likely crack/damage the inner fairing that they attach to. I kept mine on my original 93, even at warp factor 5 I figured it was the best I could do for people to see if I planned to turn from a mile away
IanDoohan is offline
99 900rr turn signals andrewmartz22 General Discussion 1 11-09-2014 9:36 AM
WTB 900rr turn signals Phanatic Wanted 0 10-06-2014 10:08 PM
need one bar end turn signals cbr 900rr robertseber Wanted 0 05-27-2009 10:55 AM
WTB 06 CBR1000RR Exhuast, Rear Fender With Turn Signals,Front Turn Signals thaiwebb Wanted 5 04-04-2008 2:37 AM
900RR turn signals Fastrr Honda FireBlade 2 01-26-2007 8:24 PM
