Regulator/Rectifier Wiring on 2003 CBR954 - Honda Motorcycles - FireBlades.org
post #1 of 6 Old 06-04-2016, 10:59 AM Thread Starter
Send a message via Skype™ to Urkie
Hi guys,
My bike left me stranded the other day next to the side of the road, flat battery. I found this hard to believe as this battery is basically brand new. I trailered the bike home and charged the battery on the Opti-Mate, which showed no errors on the battery.
I reinstalled the battery, started the bike, she ran fine. Checked the charging at the battery, and it was showing 12.1vDC on the terminals. Disconnect the terminals and the bike dies immediately. Reconnected terminals and started bike again, checked AC voltage on stator coils and all three showed about 17vAC on idle, and nothing going back to ground.
Then I proceeded to test the regulator/rectifier and found that one of the diodes in the bridge rectifier has gone. I noticed that the bike was actually fitted with an already repaired K7 GSXR750 regulator/recitifer, that had 8-wires... three yellow, two red, two green and one black.
I went out this morning and bought a new generic 65w 7-wire regulator/rectifier. I installed it, and made sure I have all wires where they should be, green to green, red to red and yellows to yellows. I did however notice that on the Honda plug there is a black with white tracer pair of wires that are wired into the same terminal. The guy at the bike shop said I shouldn't worry about them, as they serve no purpose, but I have my reservations as the black wire mentioned above on the old GSXR750 K7 regulator/rectifier ran to this terminal.
However, when I start my bike, I now get 14.2vDC at the terminals on idle, but if I remove the positive terminal while the bike is idling it still just dies.
My questions are...
Is the bike supposed to keep running, even when the battery is disconnected after starting it? As primitive as this method sounds, this is how I use to gauge roughly if a charging system works or not, but usually on older cars and bikes. I don't know if the systems still work the same, hence me asking.
What is the black with white tracer wires for on the loom side of the Honda connector? Does this have something to do with why the bike dies?
Thanks in advance.
Jacques.
Urkie is offline
post #2 of 6 Old 06-04-2016, 2:44 PM
Heeza Y Zasch
unslow1's Avatar
Quoted: 386 Post(s)
Reputation Power: 59
Re: Regulator/Rectifier Wiring on 2003 CBR954
I only have enough time to answer: YES. the bike should "die" as soon as the battery is removed. good luck with the rest, I hope someone else chimes in
unslow1 is offline
post #3 of 6 Old 06-04-2016, 4:52 PM
Quoted: 696 Post(s)
Reputation Power: 102
The bike will run only as long as the charge in the battery can keep it going. On a carbed bike it would be substantially longer (relatively speaking) than an FI bike, which requires much more juice to power all the associated electronics. If it was weak to begin with, I would assume your battery would fail almost immediately after removing the charging system from it.
Disconnecting the positive terminal from the battery while running simulates a catastrophic electrical failure and the bike will shut off immediately.
The charging system on these bike does nothing else except feed dc voltage to the battery. The battery keeps all the electronics functioning.
IanDoohan is offline
post #4 of 6 Old 06-04-2016, 7:43 PM Thread Starter
Thanks for the prompt replies guys.
Does anybody know what that black with white tracer is for on the connector? I have looked at some wiring diagrams, it seems to be a ground of some sort that runs to the engine stop relay, injectors, coils, fuel cut-off and fan relays...
Do I need to connect this to something or just leave it be?
Urkie is offline
post #5 of 6 Old 06-06-2016, 10:23 AM
Originally Posted by Urkie View Post
Do I need to connect this to something?
Yes.
You have the book, hook it up to said distance to said area. If it's all OEM parts being replaced, has a connector end, then it ends up to a tracer type [wire] and that opposite end is male/female matching the connector. Get it? There is so much length to said other connector from harness to said wired jobber's connector. Make sense saying it two ways?
Catch22 is offline
post #6 of 6 Old 06-06-2016, 2:53 PM Thread Starter
Originally Posted by Catch22 View Post
Yes.
At the cost of me looking and sounding like a complete idiot, the unit I am replacing was not OEM to start with, it's Suzuki made to work on my bike, and now I am replacing the Suzuki unit with a generic 7-wire unit. Has only 3 stator wires, two positive wires and two negative/ground wires. My bike's loom has 8 pins in total between the two connectors, 3 yellow ones which are obviously the stator coils, and on the other plug it has 2x red wires (positive as per wiring diagram), two green wires (negative as per wiring diagram) and then lastly a black wire with a white tracer.
Urkie is offline
cbr954 Not starting after replacing regulator rectifier jasonborne General Discussion 9 01-03-2013 3:13 PM
REGULATOR RECTIFIER WIRING ISSUE Ahmed Honda CBR400RR 2 09-18-2011 12:38 PM
regulator rectifier wiring help??? diggercbr Honda FireBlade 1 09-06-2010 6:44 AM
929 regulator/rectifier pete13 For Sale 4 12-27-2009 9:44 AM
rectifier/regulator wiring diagram for f4i 02 nof900RR Honda CBR 600 0 08-06-2009 9:57 AM
