I think it may be flooding? CBR954 - Honda Motorcycles - FireBlades.org
post #1 of 19 Old 06-06-2016, 6:50 PM Thread Starter
Hi guys,
I have a fairly old 954 that has done over 100,000 k's (odo stopped at 99999). The HTEV stopped working so I have taken out the htev motor and modded to remove the check engine light and fixed the exhaust unit in the fully open position, also I have screwed the flapper in a fully open position.
I have a PC3 usb and am running a two brothers full system (without HTEV) map.
Most of my riding is commuting in thick traffic every day - not really thrashing it.
My problem is - if I stop halfway home, approx 20min riding, the bike wont start (it turns over until the battery goes flat) unless I leave it for about 30 min or more.
I "think" it may be fouling the plugs - excessive fuel? and it takes 30 min to dry out?
I have changed the plugs twice in the last year thinking it was the plugs failing.
any ideas?
addict is offline
post #2 of 19 Old 06-06-2016, 8:07 PM
Heeza Y Zasch
unslow1's Avatar
Quoted: 386 Post(s)
Reputation Power: 59
Re: I think it may be flooding? CBR954
have you checked for MIL codes as per the Service Manual...? it surely could be the FPR (fuel pressure regulator)
unslow1 is offline
post #3 of 19 Old 06-06-2016, 9:02 PM Thread Starter
Thanks for your response
If there is a MIL code wouldn't the lamp light up on the cluster?
I get no FI light or anything indicating a fault.
I have checked the vacuum line on the FPR for leaks but found nothing. Can the FPR jam open to a higher fuel pressure without leaking out the vacuum line?
addict is offline
post #4 of 19 Old 06-07-2016, 5:40 AM
Heeza Y Zasch
unslow1's Avatar
Quoted: 386 Post(s)
I can't say for certain on either account... but it's worth checking (code) anyway.
unslow1 is offline
post #5 of 19 Old 06-07-2016, 8:41 AM
rikk's Avatar
Quoted: 12 Post(s)
pull the codes if any and the next time you change the plugs post some pic.'s. as many pieces to the puzzle you can give us the more helpful we may be.
fall down 7 times, get up 8
rikk is offline
post #6 of 19 Old 06-07-2016, 10:43 AM
100k miles on an engine, starting to foul plugs, anyone mention to check compression?
Signed,
NOLTT (no one likes tail tucking)
Catch22 is offline
post #7 of 19 Old 06-07-2016, 1:20 PM
Quoted: 159 Post(s)
Reputation Power: 122
Them people over there use that new fangled metric system that only a few countries use. It's only 60,000+ miles, but I see where you're going.
fj1200rj is offline
post #8 of 19 Old 06-07-2016, 7:16 PM
Quoted: 120 Post(s)
Reputation Power: 198
Forget about codes for now. If none are present during initial start up and self check don't worry about it for a minute.
What are you trying with the throttle and choke when it fails to start?
Are you using iridium plugs?
What is your normal idle speed when at operating temp?
Did you cycle the fuel pump while you had the vac line off the fpr?
jondog9 is offline
post #9 of 19 Old 06-07-2016, 9:20 PM Thread Starter
1, When I try to start I leave the throttle alone and unless im mistaken there is no choke.
2,Yes i am using the standard ngk iridium plugs.
3, from memory (I will check on Saturday) the idle is bout 800rpm when hot.
4, and i turned on the key and heard the pump when i had the vacuum line off.
Thanks for your help
addict is offline
post #10 of 19 Old 06-07-2016, 9:34 PM
I had the exact same issue that started around 25- 30K miles, it started fine while cold but i would have to do a rolling bump start every time i shut it off for a gas fill up or something else and it would literally just crank over until the batttery died. Anyway, it still had the original stock battery so i replaced it with a shorai and it hasnt had any problems since. The issue may be something else like the regulator, running rich/fouled, etc, but it appears the new battery is providing enough juice to overcome whatever was preventing it from firing up.
03' Blk/Tit CBR 954rr, Erion full system, PCIIIr, Scott's Damper, Vortex Frame Sliders, Galfer SS Lines, Rear Seat Cowl, flapper pinned.
vertical954rr is offline
post #11 of 19 Old 06-07-2016, 11:21 PM Thread Starter
Thanks.
I don't know how old the battery is, I will give it a load test when I get home (am away until Saturday).
addict is offline
post #12 of 19 Old 06-08-2016, 1:33 AM
Quoted: 120 Post(s)
I see at least part of a problem. Your idle speed should be ~1200rpm when warm.
Since the engine is still warm when try to restart, having the idle set that low could be a problem, but doesn't explain wet plugs really.
No choke on the 954's? I guess they use the wax ring thing.
If you're not having any other drivability issues, (like stalling, runs rough at low rpms, smells like gas), and you tested the fpr, I think we can rule that out.
All I can figure is it's missing enough spark to ignite the fuel under those certain conditions.
Coils? I don't know really, ignition isn't my strong suit.
jondog9 is offline
post #13 of 19 Old 06-11-2016, 1:29 AM Thread Starter
Ok.
I started the bike after sitting for a week, it started well. I warmed it up to 100 degrees - idle was 1200 rpm, stopped it. Tried to start again, seemed a little weak but started, turned off and tried gain - wouldn't start.
Left it for about 20 minutes, tried starting - wouldn't start.
Waited another 20 min and tried again - turned over a few times and started then backfired like a shotgun!! very loud.
I took a video but didn't manage to get the backfire.
about 4 minutes - sorry if its a bit tedious.
gets interesting at about 2:45
addict is offline
post #14 of 19 Old 06-11-2016, 2:22 AM
Throttle sync = Usually starts faster.
Throttle angle = I'd just crack the throttle open when starting... looking for some idiosyncrasies to it.
Catch22 is offline
post #15 of 19 Old 06-11-2016, 11:33 AM
Quoted: 120 Post(s)
Glad you mentioned that. I was thinking the same thing about cracking the throttle open a tad. That's why I asked what he's doing with the throttle and choke. I hesitated to recommend, cause I didn't really know, but it's worked for me in the past when I had fpr issues.
jondog9 is offline
CBR-600 F4I - Flooding? Please help! charles8998 Honda CBR 600 28 07-28-2019 1:12 PM
Flooding? Kellan Honda CBR 600 6 06-07-2012 12:36 PM
Flooding 929 DaveM Honda FireBlade 20 02-27-2006 12:50 PM
954 Flooding? automan Honda FireBlade 3 09-23-2005 7:36 PM
we're flooding? showmethebombs General Discussion 5 05-20-2003 8:14 PM
