Help with wiring - Honda Motorcycles - FireBlades.org
post #1 of 5 Old 06-16-2016, 1:38 AM Thread Starter
Help with wiring
So i bought this 900rr and the clutch diode and switch on the clutch lever were burnt. i replaced the diode and switch. But the starter relay fuse blows and the green N light stays on with key off or on. Also starter wont in engage with switch. Im stumped
Cbr900rrguy is offline
post #2 of 5 Old 06-16-2016, 8:07 AM
Re: Help with wiring
Pull the new switch out of the loop. Does the N light go out key off? See where to look start looking now?
Catch22 is offline
post #3 of 5 Old 06-16-2016, 1:11 PM Thread Starter
No stays on and still no start
post #4 of 5 Old 06-16-2016, 1:46 PM
Quoted: 696 Post(s)
Reputation Power: 102
Hey chip and dale , remember this thread from 3 weeks ago
https://www.fireblades.org/forums/hon...oide-help.html
Not even a thanks?
WTF
Well, it's a good thing I don't judge or hold grudges.
Was hoping for some background in the thread I posted in, but you didn't provide any. Still need that.
Generally a neutral light that stays on even when in gear is a grounded wire in the harness, fooling the switch into thinking it's not in gear. You'll have to trace that to rule out a bad switch and what wire may be damaged.
Did you have any other electrical issues up to the clutch diode failing? They usually don't just fail. They typically need some other electrical issue to come about, such as a charging system failure that leads to burned insulation, wires grounding out, etc. If it's not found early, catastrophe can happen and connectors (especially the starter relay) can melt and ruin the associated wires. That's typically why the main fuse blows.
Start with a bit of background leading up to the ruined clutch switch/diode and more specifics.
Looking forward to it.
IanDoohan is offline
post #5 of 5 Old 06-16-2016, 6:09 PM
Originally Posted by IanDoohan View Post
Not even a thanks?
Expecting a thanks on the net? They can suffer with their problems if I feel the needed for a thank you. Goes with the territory so you suck it up. On the other hand, I let the squid have it just so no thanks is coming anyway, see how they like the social event.
Catch22 is offline
reg/rec wiring nzblade Honda FireBlade 2 07-04-2011 5:08 AM
Help Pls.. Wiring.. Maholli Honda RC51 11 06-05-2010 6:50 PM
Help With Wiring SoliceDreamer General Discussion 11 11-29-2009 4:19 PM
need wiring help please bryanclapper69 Honda FireBlade 2 08-16-2007 11:14 AM
Wiring Help flyridecr125 Honda FireBlade 1 01-20-2007 6:24 PM
