99 cbr 900rr Fueling options for syncing carb - Honda Motorcycles - FireBlades.org
post #1 of 6 Old 06-22-2016, 1:08 PM Thread Starter
Ok, I am about at my wits end with this bike because of how damn awful impossible it is to find EVERYTHING for it. Turn signals, mirrors, headlights assemblies, ignition modules.... I spend more time researching how to fix it than I have riding the got danged thing.....
ok, ranting done, now for the question... I need to tune and sync my carbs for my 99 RRX, and as you know, the tank is too damn heavy and unbalanced to hang, and the petcock position and height of the bike make it hard to just put the tank on a table. I was going to just buy an auxiliary shop gas tank off amazon, but the fuel line to the tank comes with is a 1/4 line with a 1/8 or 3/16 inner diameter... well the bike uses the damn 3/8 line with a 5/16th inner diameter, so what the hell am I supposed to do now???? any suggestions? cause I have dropped this tank and had gas dribble all over and out of it so much I have had to repaint it three damn times.....
BluntBlade99 is offline
post #2 of 6 Old 06-22-2016, 4:29 PM
Reputation Power: 50
Re: 99 cbr 900rr Fueling options for syncing carb
Plastic bottle, I use a Scotoiler oil container. Plastic pipe with the right O/D to fit in the fuel line, push it all the way in, if it dribbles, a tie wrap seals it. Cut the bottom from the bottle, tie it up to an overhead joist etc.
Good luck getting the inlet blanking screws out, easier if you whip the carbs off. I made adapter pipes up and leave them in place, seal with a rubber bung when done.
jdugen is offline
post #3 of 6 Old 06-22-2016, 5:13 PM Thread Starter
should have known it would be a simple answer like that...... Ill come up with something usable. Mean time Im going to order a petcock that will work for shutting the fuel on and off... Thanks jdugen.
And yes, the vacuum screws are stupid hard to get off and I had to buy an extra set of adapters cause the ones that came with my synchronizer were too long. I really should have invested in the adapters like you got, but hindsight is 20/20 and I already got the tubes on....
post #4 of 6 Old 06-22-2016, 5:40 PM
Reputation Power: 8
Personally, ordered a set of brass adapters from here:
Morgan Carbtune - carburetor synchronizer for balancing motorcycle carbs
and then got some rubber bungs for the ends so they are permanently in place (one currently feeds the vacuum pipe for the fuel tap).
Works a treat
As for the fuelling, i just ordered a proper secondary tank from demontweeks, as i made up my own for a bit but after a reasonable amount of use it wasn't lasting.
Warrior Auxiliary Fuel Tank | Demon Tweeks
cbrherms is offline
post #5 of 6 Old 06-22-2016, 11:14 PM Thread Starter
Loving that price, cbrherms, but what is the size on the fuel line? I really hate that demon-tweeks isn't even trying to advertise that, and like I said, I'm done buying stuff that I have to buy OTHER stuff to make it work properly....
post #6 of 6 Old 06-23-2016, 3:18 AM
Reputation Power: 8
Admittedly I had to use plumbers tape on the petcock to size it up the extra 1mm for the 98 blade.
But, totally get what you mean!
cbrherms is offline
Tags
adjustment , carb , carbueretor , sync , synchronizer
Options to run filter on carb setup? bonylad Honda CBR 600 2 10-08-2015 8:25 AM
Looking for mirror options for 95 900rr Novicoupe Honda FireBlade 1 07-30-2013 1:56 AM
98 900RR exhaust options lxtasy Honda FireBlade 7 08-13-2009 8:43 PM
Rearset options for the 900RR? cbrsmurf Honda FireBlade 19 06-16-2008 6:24 AM
900rr engine options literbike Honda FireBlade 16 12-05-2007 8:05 PM
