'95 900rr Tank Venting Issue - Honda Motorcycles - FireBlades.org
post #1 of 4 Old 06-25-2016, 10:21 PM Thread Starter
Hi Gents
This is a puzzler!
I have confirmed the vent line through the tank is clear. I can hear compressed air escaping into the tank with the cap opened - so it's venting right?
Well today on a 100 mile ride I stopped for fuel. When I opened the cap the tank had so much pressure it was crushing itself! ON much shorter rides I can hear the air flow when I open the cap but nothing of this magnitude.
If the line is clear how in the world can the tank be gaining negative pressure? Not sure what I'm missing - help!
Thanks for any advice
Edit: After further research I may confused the two vent lines. I assumed the larger line is the vent - is this the overflow? Meaning the smaller line is the tank vent and is plugged?
Old_Bourbon is offline
post #2 of 4 Old 06-26-2016, 12:49 AM
Quoted: 694 Post(s)
Reputation Power: 102
Re: '95 900rr Tank Venting Issue
Larger hose/nipple is overflow - small hose/nipple is vent
My Red Rocker 93 Build Link: Cafť 900RRP
IanDoohan is offline
post #3 of 4 Old 06-26-2016, 1:05 AM Thread Starter
Thanks for the info!
What are your thoughts on going with one of the Vortex fuel caps? Instead of trying to unplug the line in the tank that may be fragile from years of sitting I could just plug the nipple on the tank and rely on the vortex for venting?
I can just see the lines in the tank and they look a bit "rough". I think the overflow is OK but the smaller one - ugh
post #4 of 4 Old 06-26-2016, 1:00 PM
Yes, a votex and call it a day. Leave the brittle parts alone.
The 100mi tour is hot air expanding that is being tackled from under is the engine heat and the sun beating down on it as you ride an empty tank.
100mi = Pressure expanding pops the cap up. Pressure is able to push the fuel down and out the petcock = 100mi think.
1 mile or less = Vacuum is going to vapor lock the air you can't pull the cap up and that is no flow = Top off the tank and there is the least amount of air about to lock the flow even faster = 1mi or less.
Make sense?
How-to distinguish between a 2 and 3 fuel tank pipe nipple ends:
Use a long hose to blow in a nipple as you have the cap up and your ear/face close to the opening. Visually look at the first two pipe opening ends at the top of the tank filler opening.
1. Small tube: Looking down at the tank's recess well or the bottom of the neck. There is an-overflow hole. This is for washing/caught in rain/filled gas over the neck; drains to the ground.
2. Large tube: This is where the cap is still up, you see an oring around the filler neck someplace? Blow in the large nipple end and air should be sent out the hole around that oring.
3. Cali tube: This optional nipple sits up at the ceiling of the tank and captures vapor.
Tank venting ideas:
A. Horseshoe the weather vent tube to the large gas cap vent tube.. no air filtering unless you pencil strand out a cotton ball and shove it up the tube. Rain/wash water sits in that horseshoe and will be sucked in = High maintenance.
B. Run a hose from large tube up the tail end, zip-tie a cotton ball over the hose end for filtering.
C. Run the nipples open and let the liquids fall where it may. Zip-tie a cotton ball over the big nipple end(s).
Catch22 is offline
F2 gas tank issue!! bazzledazzle Honda CBR 600 6 11-01-2012 7:49 PM
Gas Tank not Venting TucsonShadow General Discussion 4 07-18-2012 11:21 PM
929RR - Installing gas tank issue Robles929 General Discussion 2 07-29-2011 12:14 PM
HTEV Sux, just venting simple guy Honda FireBlade 1 02-09-2007 9:28 PM
Venting about Ron Ayers Blitzen Vendor / Seller / Dealer Reviews 18 04-22-2004 7:06 PM
