1996 Fireblade Build - Honda Motorcycles - FireBlades.org
post #1 of 30 Old 06-25-2016, 10:56 PM Thread Starter
Reputation Power: 4
So I recently acquired a 1996 'Blade in semi-okay shape (great mechanical condition, so-so cosmetically). PO definitely rode her hard, as evidenced by the molten rubber lining the rear undertail and the fact that the motor has been replaced with a 1998 model. Here she is the day I got her.
No pics of the initial teardown but suffice it to say the harness was a bit of a mess. I still need to get back in there and properly wire the turn signals as well as replace the plugs for the headlight. I will re-wrap the harness in Tesa fabric tape once I get it all buttoned up. Here are some pics from today.
No idea of the mileage on her. ODO say 51k but with the motor swap speedo reads 185 at 25. SpeedoHealer is ordered to rectify that issue but it also means I'll never know the actual mileage on the chassis, let alone the motor. As can be seen in the photos, the frame, swing-arm, and triple clamps have been polished. That'll stay til I can afford powder coating (which probably means a long time lol). Fan switch is bad, as evidenced by the wire being grounded to the header to keep the fan on at all times. Has a K&N fillter and a ratty Two Brothers slip-on. Of course it hasn't been jetted accordingly so it runs a bit rough. One or both of the throttle cables have been pinched so the bike doesn't return to idle unless you twist the throttle closed. Rear tire is new, front is junk. The right peg bracket is tweaked. The brake lever is broken and has a bolt with a bit of hose passed through the broken off portion. Overall, it's got good bones I just need to figure out what to do with them.
Parts on order:
SpeedoHealer
Fan Control Switch
Front Tire (Shinko Podium 006)
Both Throttle Cables
Parts to order:
Front fender of some sort
Front sprocket cover (need one from a 98/99)
Matching tire for the rear (I will sell the current tire to recoup, OCD and past experience scream out against mismatched tires)
Parts I want:
HealTech Quickshift
HealTech Gear Indicator
Factory Pro 4* Timing Advance
Factory Pro Shift Kit
Factory Pro Airbox Plus kit
Delkevic 4:1
Cosmetically, I am at a loss as to what I want to do. On one hand, I could order plastics and take it back to factory appearance. However, for that to happen I need the entire upper cowl, a headlight, and both mid panels. I have had rotten luck finding anything reasonably priced so far. The other option I have been entertaining out of necessity is the naked fighter look. I could grab a belly pan and a headlight kit and call it a day. Any thoughts or inputs here would be nice. Thankfully, the tank and tail are pretty much perfect so I catch a break there.
shadowfocus603 is offline
post #2 of 30 Old 06-26-2016, 6:01 AM
Quoted: 4 Post(s)
Re: 1996 Fireblade Build
I see your problem with your speedo, On 96 models the speedo sensor attaches to the front sprocket cover. So you need a front sprocket cover from a 95-97 and a speedo sensor. Do not buy a 98-99 front cover as the speedo comes from the gear box and will not work with your clocks.
BLOB748 is offline
post #3 of 30 Old 06-26-2016, 10:20 AM Thread Starter
Reputation Power: 4
Since the motor already has the later speedo sensor reading the trans gears that's why I decided to just get the SH and use what I have. I might end up getting the earlier sprocket cover and sensor but then I'd need a block off for the trans sensor on my later motor.
post #4 of 30 Old 06-26-2016, 1:22 PM
Quoted: 696 Post(s)
Reputation Power: 102
Leave the bike as a RR. I went with the cafe/streetfighter look on my last 93. Now I want the fairings back on it. The bike will thank you later
Looking forward to seeing your progress either way
IanDoohan is online now
post #5 of 30 Old 06-26-2016, 2:23 PM
Quoted: 4 Post(s)
Reputation Power: 9
Mine looked very similar to yours when I got it. It was tired but most everything was there but needed redone.
This is what it looks like after I finished it. I agree with IanDoohan. Leave it as a RRG]
Motleyfan is offline
post #6 of 30 Old 06-26-2016, 3:01 PM Thread Starter
Reputation Power: 4
Thanks for the encouragement Ian. And Motley your bike looks great. Not really a fan of the white tail but to each their own. I don't have to decide on the cosmetics for awhile ($$$) so I will mull the decision for awhile and cross the bridge when I get to it. For now, I just want the bike spot on mechanically.
post #7 of 30 Old 06-27-2016, 8:38 PM Thread Starter
Reputation Power: 4
SpeedoHealer installed and programmed tonight. Also installed new fan control switch. I originally thought the fan control switch sent signal to the temp gauge. Obviously I was wrong. I apparently need to replace thermo sensor as well. Question to you all. Will my '96 temp gauge read the signal coming from the '98 thermo sensor?
post #8 of 30 Old 06-27-2016, 9:18 PM
Quoted: 696 Post(s)
In regards to the thermosensor. It will not work. 93-97 = analog gauge. 98-99 = digital gauge. Also, it was confirmed years ago with the 600F4i dash mod. You have to replace the older ones with the 98-99 for th temp to display.
post #9 of 30 Old 06-27-2016, 9:47 PM Thread Starter
Reputation Power: 4
So is it safe to assume the earlier thermosensor will bolt right in to the later water housing? I have looked at sensors for the different years but all seem to use the same stock image.
post #10 of 30 Old 06-28-2016, 7:38 AM
Quoted: 696 Post(s)
Yes.
post #11 of 30 Old 06-28-2016, 8:38 AM
Quoted: 4 Post(s)
Reputation Power: 9
I got a set of used unripped seats if you interested for a 96.
post #12 of 30 Old 06-28-2016, 4:35 PM Thread Starter
Reputation Power: 4
Motley I'm definitely interested. Let me get back to you on them. I have a few other bits right now that take precedence. And thanks for the confirmation Ian.
post #13 of 30 Old 06-28-2016, 5:46 PM
Gunk's Avatar
Quoted: 496 Post(s)
Reputation Power: 23
I agree with other posters about not going down the Streetfighter route, it destroys the value and the bike is far more desirable with the plastics.
This was my 1994 when I bought it, worse than yours.
And now
Gunk is offline
post #14 of 30 Old 06-29-2016, 6:26 PM Thread Starter
Reputation Power: 4
Someone got a visit from the tire fairy lol.
I know a lot of people give Shinko grief but I have a set of 712's on my 850G and I have zero complaints. I have pushed them hard with absolutely no ill manners. Hopefully these serve just as well. Will be getting the matching rear once funds re-accumulate.
post #15 of 30 Old 06-30-2016, 6:38 PM Thread Starter
Reputation Power: 4
Do any of you folks have a suggestion for baseline jetting for a slip-on and a K&N filter? Going to pull the carbs this weekend or next and want to get everything together. I have the tool coming for the mixture screws so if you have a suggestion for those I'd appreciate it as well. I will be buying a jet kit in the future but would like to get the bike semi close as is. At least rideable untill I have the $$$ for the kit.
My 98 fireblade, the start of a build Krystalized_jdm Honda FireBlade 1 10-09-2014 9:16 PM
1996 fireblade RRT longhorn0_7 General Discussion 3 12-16-2013 12:41 AM
92 Fireblade Build adam.m Honda FireBlade 7 06-02-2013 5:11 AM
1996 RR-S Fireblade whysub Motorcycles For Sale 2 06-11-2011 4:20 PM
1996 fireblade top yoke, will it go on a 2001 929 fireblade ahoulding Honda FireBlade 1 10-31-2010 9:27 AM
