03 954RR idle issue on start up - Honda Motorcycles - FireBlades.org
post #1 of 3 Old 06-26-2016, 7:47 PM Thread Starter
hello everyone i have a 954rr with 18xxx miles and when i start the bike i have to hold the throttle or the bike will shut off. after about 10-20 seconds the bike will idle perfectly as if there is no issue. whether its warm cold it makes no difference. i can ride for 2 hours stop to get gas or do anything for just a second or hours and it does the same thing. rough when it first starts i have to play with the throttle and hold it for 10-20 seconds then it idles beautifully. i am a auto mechanic so im very mechanically inclined just not to familiar with bikes even tho i know they are pretty much the same. the issue is annoying and idk what else to do. i checked the normal spark plugs, air filter, fuel filter etc
ilmf86 is offline
post #2 of 3 Old 06-26-2016, 8:14 PM
Heeza Y Zasch
unslow1's Avatar
Quoted: 386 Post(s)
Reputation Power: 59
Re: 03 954RR idle issue on start up
welcome to the site ...and the world of 954 electrical issues
I'd like to take a guess and say your MIL (red LED on the gaugepod) is illuminated? if so, do you know how to check for codes?
I have an idea what's wrong with it, but it's purely an educated guess without knowing a code.
Looking forward to your reply.
unslow1 is offline
post #3 of 3 Old 06-26-2016, 8:36 PM
Heeza Y Zasch
unslow1's Avatar
Quoted: 386 Post(s)
If you don't know how to check for codes... or don't want to... lift the tank (the prop rod is under your seat), and CAREFULLY remove the airbox. There's a sensor (both vacuum and electrical) attached to the bottom RIGHT (brake side) of the airbox and wedged between the frame. It is the MAP sensor. Since I'm guessing here, I'd say the vacuum line has come UNplugged. MAP sensor failure is "2 Blinks" when using the self-diagnosis plug found under your seat.
If that's not it, I hope this post at least helps someone else who may have come across this thread in the future.
unslow1 is offline
cbr 954 rr idle issue vancev General Discussion 6 06-18-2015 4:43 PM
cbr 954 cough, idle issue samba2 Honda FireBlade 0 08-27-2013 7:43 AM
CBR 929 idle issue jamesfs912 Honda FireBlade 12 12-24-2009 11:11 PM
idle issue kuziken Honda CBR 600 2 04-03-2009 8:14 PM
fast idle issue Firehawk Honda FireBlade 5 03-08-2007 1:35 PM
