954 RR3 Throtle - Honda Motorcycles - FireBlades.org
post #1 of 5 Old 07-21-2016, 2:37 PM Thread Starter
Quoted: 19 Post(s)
Reputation Power: 4
954 RR3 Throtle
I moved my right hand switch gear to adjust it and fastened it back up , it does not spring back now the 2 casings appear to be ok any suggestions
Leslie is offline
post #2 of 5 Old 07-22-2016, 12:10 AM
Quoted: 16 Post(s)
Reputation Power: 9
Re: 954 RR3 Throtle
Maybe the grip is squeezed up againt the switch gear housing. Put a little grease in there. Are the cables lubed and properly routed?
coalminer frank is offline
post #3 of 5 Old 07-22-2016, 1:00 AM
Quoted: 48 Post(s)
Reputation Power: 48
Re: 954 RR3 Throtle
the controls arent meant to be adjusted. the clip on bar has a small hole and the switch housing has a pin that goes into the hole. maybe im not clear on what you mean by adjust it.
most likely its something simple, my advice would be to take is back apart, make sure its lined up and the pin is in its place and check for something binding not allowing the throttle to return.
954Kevin is offline
post #4 of 5 Old 07-22-2016, 12:45 PM Thread Starter
Quoted: 19 Post(s)
Reputation Power: 4
Re: 954 RR3 Throtle
Kev, I feel a bit embarrassed, I think Suzuki and Honda have a little locating pin/key that locates into a small hole in the handle bars, I have put pro taper contours on my blade (CR High) so obliviously the switch gear/throttle is not seating right, 1/8th drill bit job done.
Leslie
MANCUNIAN BY BIRTH MCFC BY THE GRACE OF GOD AND ALAH - DOGS AMONGST THE BUSHES-LOVE WILL TEAR US APART
Leslie is offline
post #5 of 5 Old 07-22-2016, 3:08 PM
Quoted: 48 Post(s)
Re: 954 RR3 Throtle
Leslie
happy you sorted it out leslie. : )
954Kevin is offline
CBR 954 RR3 2003 - UK - 700 Slimat Motorcycles For Sale 1 10-22-2014 12:53 PM
Sweetest Exhuast for 954 RR3 shiney Aftermarket Perfomance Parts Reviews 2 09-24-2010 5:19 AM
download for cbr 954 rr3 ozzie9962 Honda FireBlade 0 06-19-2009 10:00 AM
954 RR3 valve ticking. murtonm Honda FireBlade 5 09-17-2008 10:24 PM
954 rr3 rear section graphics bregazzi Honda FireBlade 10 05-06-2004 11:49 AM
