2001 929 fuel issues - Honda Motorcycles - FireBlades.org
post #1 of 117 Old 07-27-2016, 3:27 PM Thread Starter
Reputation Power: 4
I was test riding my bike after I got all the "bugs" out of it. It has a new stator, new mosfet rectifier, new battery, oil, etc. I got about 100 yards down the road, stopped at the stop sign, took off in first and the bike took off fine. As soon as I hit second the bike just died and hasnt started since. I checked for spark, it has spark along with new iridium plugs. Yes, there is gas in the tank. The fuel pump primes every time. The kickstand killswitch works perfectly. I recently had a fuel pump go out in my S-10 and it had the same effect of my truck just shutting down immediately, but I knew it was the fuel pump because it would never prime upon ignition. My question is even though the fuel pump primes on the bike does that mean it's any good? My truck stumbled a bit when the fuel pump went out because I didnt have my foot to the floor. I was definately giving the bike full throttle so I can see how it would just cut off instantly. My bank angle sensor works fine along with the fuel cut relay. It really feels like a fuel pump at this point, but any advice, without condescension is greatly appreciated. Yes, I have read a ton of threads. This is a used, "new" bike to me. This bike would start up every time while i was doing all the other stuff i needed to do to it. I was making sure everything was kosher before investing in new tires. Finally got to that point, new tires on, 100 yards from the house and now I have a bike with new tires sitting under a tarp. Murphy's Law in full effect. Please don't reply with some cocky garbage, my patience is thin skinned right now. Thanks in advance.
carolina_erion is offline
post #2 of 117 Old 07-28-2016, 2:37 AM
Re: 2001 929 fuel issues
Dude, 30 hits and I'm it. Say you're throwing the dice of how many hundreds at it, and if it's not? And my common sense, not to be throwing the pie in the face, says I'm making sure one variable is out of the way before I throw a dime at it. Because I am still showing fuel pressure and spark is the way I'm reading it.
Signed,
I do not chase my tail or suffer fools under a tarpie.
Catch22 is offline
post #3 of 117 Old 07-28-2016, 7:10 AM
Reputation Power: 8
Do you have any MIL light on dash?
alan_ford is offline
post #4 of 117 Old 07-28-2016, 9:42 AM Thread Starter
Reputation Power: 4
Since I'm new to the bike, all i can tell you is i have a red light next to the green nuetral indicator. Nothing flashing.
post #5 of 117 Old 07-28-2016, 9:45 AM Thread Starter
Reputation Power: 4
Thank you, that was very helpful?
post #6 of 117 Old 07-28-2016, 3:36 PM Thread Starter
Reputation Power: 4
Signed,
You clearly did not read my post. The bike was running. All the stuff I did to it were needed, I didn't just start buying parts and hoping for the best. I got the bike running before I threw tires on it, then it decided to go to hell. Thanks for the reply though, it was very helpful...Dude.
post #7 of 117 Old 07-28-2016, 3:48 PM
rikk's Avatar
Quoted: 12 Post(s)
do you use the kill switch or the key to shut the bike off?
fall down 7 times, get up 8
rikk is offline
post #8 of 117 Old 07-28-2016, 3:50 PM
rikk's Avatar
Quoted: 12 Post(s)
if the pump is priming you will have pressure. the pump either works or it has craped the bed there is not really a middle ground.
rikk is offline
post #9 of 117 Old 07-28-2016, 4:06 PM Thread Starter
Reputation Power: 4
That's what I needed to know, thanks. Time to get the voltmeter out and start checking grounds, etc. The way my luck goes the ecu is probably done after all the **** I've had to do to this thing.
post #10 of 117 Old 07-28-2016, 4:43 PM
rikk's Avatar
Quoted: 12 Post(s)
check the kill switch as well these are notorious for failing.
rikk is offline
post #11 of 117 Old 07-28-2016, 7:00 PM Thread Starter
Reputation Power: 4
g.
Thanks for the advice, it's been hot as hell down here so i'm waiting for some cooler weather where I can look into the wiring and make sure all is well before I decide to dump this bike into a deep lake somewhere.
post #12 of 117 Old 07-28-2016, 7:03 PM Thread Starter
Reputation Power: 4
If it were the kill switch though, would it even prime the pump or attempt to start? The starter engages.
post #13 of 117 Old 07-28-2016, 8:40 PM
Quoted: 51 Post(s)
Reputation Power: 98
It's not the killswitch under these circumstances....these bikes are notorious for ECU issues.....that would be the first place to check.....as a side note you need to relax a little when people are taking their time to help you....just a suggestion...........
oxman1196 is offline
post #14 of 117 Old 07-28-2016, 11:41 PM Thread Starter
Reputation Power: 4
Relax? Not really sure where that's coming from? I was only commenting negatively on that first dumb reply that made no sense. I've thanked the people that had good tips for me. If you knew how much trouble this bike has been maybe you would understand how frustrating this deal has been. Thanks for all the tips to everyone that has given me some. I'm pretty easy to get along with
post #15 of 117 Old 07-29-2016, 9:21 AM
Reputation Power: 8
You have spark, and the pump is priming. Need to check is there fuel going in throttle bodies.
Unbolt the tank, take air box off. Do not disconnect fuel line.
When you crank the angine, turn the throttle, you should see fuel spraying thru thrrotle bodies.
If it is not spraying, check the injectors connector.
If it is loose you would probably have MIL blinking.
If fuel pump primes, and injectors are not spraying, check IGNITION sensor, on the right hand side of the bike.
Its job is to tell the ECU when to trigger injectors.
Tags
fuel pump , no fuel
HELP: 01 929 Fuel issues Blaze713 Honda FireBlade 5 06-24-2016 9:54 AM
2000-2001 929 fuel pump !!A2K!! For Sale 1 12-19-2012 11:00 AM
2001 929 Brake issues. tex929 General Discussion 13 12-20-2010 7:03 PM
2001 929 Issues - help slyde Honda FireBlade 2 10-25-2008 4:25 PM
2001 929 w/ Airtech, Need advice on various issues jrepp Honda FireBlade 5 05-19-2006 12:36 AM
