HELP Cam Chain Tensioner Removal - Honda Motorcycles - FireBlades.org
post #1 of 6 Old 07-31-2016, 2:22 PM Thread Starter
Reputation Power: 8
Good morning Blade lovers,
I started to do some maintenance on my baby, and I am stuck. I cannot figure out how to unbolt the Cam Chain Tensioner. I moved up the wiring harness out of the way and the coolant hose, but, I still cannot insert a 8mm socket, or open end wrench, or a gear wrench. How am I supposed to unbolt it?
thank you in advance
02CBR954AD is offline
post #2 of 6 Old 07-31-2016, 6:14 PM
Quoted: 17 Post(s)
Reputation Power: 8
Re: HELP Cam Chain Tensioner Removal
There's a few past helpful threads floating around out there (found via the search function - here's a couple that might help?) :
https://www.fireblades.org/forums/hon...er-fixems.html
https://www.fireblades.org/forums/hon...on-issues.html
-'02 Silver/Black CBR 954RR
-'06 Black/Metallic Gray RC-51
-'11 Graphite Black CBR 1000RR
(sold)
-'08 Pearl Orange CBR 600RR (sold)
COBRA90GT is offline
post #3 of 6 Old 08-01-2016, 12:58 AM
Quoted: 48 Post(s)
Reputation Power: 48
to actually remove the cct on my 954 i had to remove the left fairing. lift the tank, remove the airbox, pop the throttle bodies off, but not fully remove, n push them to the left side of the bike to get a small open ended wrench on the upper bolt to loosen it. on mine i couldnt get a socket on the bolt because it was too close to the frame to put one on it.
the bottom bolt i put my arm thru the hole between the frame and the engine just above the transmission with the fairing off.
both were a tight squeeze.
i had put a manual ape cct on but after realizing i was gonna hafta do this procedure every time i wanted to adjust or even just make sure the locking bolt hadnt backed off, i removed it and put the automatic unit back on. it was a pita for sure.
954Kevin is offline
post #4 of 6 Old 08-01-2016, 9:54 AM
Reputation Power: 26
8mm small ratcheting wrench. Kobalt to be exact...
You have to loosen the harness (ziptie thing), then bend it some.
I think I had the tank lifted but left the fairing on, as Kevin stated, reach above the clutch cover. My other hand (left) I believe was over the frame and under the tank. It's a lot of fiddling and maneuvering until it is perfect.
Made my own CCT holder out of a feeler gauge too if the new one did not come installed, I think it did...?
Just a dremel and thick feeler gauge.
Honda CBR 954RR (Leslie)
Suzuki SV650-K2
Camper is offline
post #5 of 6 Old 08-01-2016, 9:56 AM Thread Starter
Reputation Power: 8
thank for all help, 5 min after posting this I had it out. what I had to use to unbolt the top 8mm bolt by the frame was a thin 8mm open end wrench, it came out easy. to install fallowed procedure and used same thin open end wrench. did not have to remove tank or TB's
post #6 of 6 Old 08-01-2016, 9:57 AM Thread Starter
Reputation Power: 8
thank for tip, now the CCT come with their own holder it looks like yours but smaller. 1st use a small flat head screwdriver to twist CCT to right to loosen it, thne insert the key to hold in place
Cam chain tensioner oquainb Honda CBR 600 24 02-05-2016 4:29 PM
Cam chain tensioner Andy1980 General Discussion 2 05-06-2014 4:32 PM
Cam chain tensioner Midwestrider Honda FireBlade 0 08-02-2011 12:31 AM
cam chain tensioner removal Midwestrider Honda FireBlade 14 07-27-2011 5:43 PM
cam chain tensioner biglos Honda FireBlade 18 09-25-2010 12:02 PM
