2nd gear issue - Honda Motorcycles - FireBlades.org
post #1 of 4 Old 08-01-2016, 12:54 PM Thread Starter
Doe
2nd gear issue
I have been told that this is the 900rr's only chronic problem. It jumps out of second gear. Is it an expensive fix? Time consuming? I'm a very proficient DIY guy so is it something I may be able to do myself?
Doe is offline
post #2 of 4 Old 08-01-2016, 5:27 PM
Re: 2nd gear issue
Hi Doe, I have the same problem unfortunately.
I have already bought the new parts 2nd & 6th gears ready for the winter project, from what i can gather the hard part seems to be removing the engine, I am going to give it a go myself.
What's the worst that can happen
stubooth is offline
post #3 of 4 Old 08-02-2016, 3:48 PM
Quoted: 29 Post(s)
Re: 2nd gear issue
See this thread https://www.fireblades.org/forums/hon...n-problem.html nothing is impossible, i once fixed a ZX9r gearbox in a gazebo on the patio, as i didn't have a garage at the time.
Spaz is offline
post #4 of 4 Old 08-04-2016, 6:58 AM
Reputation Power: 4
Re: 2nd gear issue
I would hold off on buying parts until you have the engine out, be prepared as this will be a big job, but not hard. Make sure you buy a factory manual as this will help you big time.
I had the same problem on a FZR 600 years ago, it turned out to be the gear shaft, it had worn and was causing the bike to jump into neutral, once it hit 7000 rpm.
If you haven't done anything like this before try and find someone to help you.
JayX is offline
2nd Gear Issue HondaFan94 Honda CBR 600 2 07-20-2016 4:04 AM
2nd gear!!!! :( Bella400 General Discussion 3 08-30-2013 4:46 PM
2nd gear tranny issue!!!!! 97mitsurs Honda FireBlade 3 03-30-2012 11:32 AM
2nd gear IFMISM Honda FireBlade 2 01-31-2011 7:48 AM
I have NO 2nd gear!!! RidAnyThatRuns Honda CBR 600 12 06-14-2010 1:54 PM
