94 900RR muffler question - Honda Motorcycles - FireBlades.org
post #1 of 10 Old 08-10-2016, 1:18 PM Thread Starter
Hey guys, I haven't been on this forum in a while, but here's my question. Would their be any problems if I were to replace my stock can with one off an F2? My stock can got damaged, and I have one from an F2 600,the bolt pattern is the same and it fits. So would there be a problem with back pressure if I were to swap them out?. Thanks in advance for any input... …Fitzman.
Fitzman is offline
post #2 of 10 Old 08-10-2016, 4:00 PM
Quoted: 711 Post(s)
Reputation Power: 102
Re: 94 900RR muffler question
That doesn't make any sense, the F2 cans weren't a stand alone can. They came with the mid pipe attached. If you have a black, 3bolt patern can, it's for a 900, or another make with a similar bolt pattern, not an F2.
I don't think what ever it is you have will hurt your set up. Should run fine. Try it out.
IanDoohan is offline
post #3 of 10 Old 08-11-2016, 12:51 PM Thread Starter
OK, thanks for the feedback Ian. Yes the stock can is black, and the only way I am identifying the other one is that it says Honda F2 stamped on it.(It's silver, by the way).
After installing the other can I could not notice any difference from the stock black one.. My concern was that since the F2 can supposedly came off a 600,my motor might not be able to "breathe" enough up top? (High rpms) I like how quiet the bike runs, but don't want to sacrifice any more power than I have to.
Hope this makes sence.Any other input, sugjetions or comments would be great.
Thanks again, for your help….….Fitzman.
94 CBR 900RR..Box stock.
Fitzman is offline
post #4 of 10 Old 08-11-2016, 12:55 PM
Quoted: 198 Post(s)
Reputation Power: 25
Can you post a picture of the F2 exhaust and that of the stamping?
lanbrown is offline
post #5 of 10 Old 08-11-2016, 1:20 PM
Quoted: 711 Post(s)
The 96-97 900 came with a silver can, and probably has the same bolt pattern. Does it have this stamped on it or something similar? If so it's an OEM Honda muffler for the aforementioned 900 years. And should be fine to use. This one happens to say F1 on it.
post #6 of 10 Old 08-12-2016, 2:29 PM Thread Starter
Yes, there is a similar stamping on the can, the only difference is there is an F2 instead of the F1 on the one in the picture.
So basically I'm OK using the one I have, till I can get my hands on a good aftermarket can? Thanks again for the input.. Fitzman...
Fitzman is offline
post #7 of 10 Old 08-12-2016, 4:37 PM
Quoted: 711 Post(s)
Yes, good to go
post #8 of 10 Old 08-12-2016, 6:59 PM
Gunk's Avatar
Quoted: 500 Post(s)
Reputation Power: 24
Here is a standard 1994 CBR900RR-R exhaust silencer
Gunk is offline
post #9 of 10 Old 08-20-2016, 4:57 PM Thread Starter
Yes, that's the one that I just removed, So from what I'm taking away from your input, Is that I'm doing no damage by running the F2 pipe.?
The bike runs pretty much the same as with the stock one.
Last question, Can anyone recomend me a can that will not require me to rejett ,while boosting low end to midrange?
Fitzman is offline
post #10 of 10 Old 08-20-2016, 6:39 PM
Quoted: 198 Post(s)
As previously mentioned, the F2 does not mean CBR600F2. The CBR600F2 never had a bolt-on arrangement like the 900RR had; the CBR600F2 was all one piece for the entire run of model.
Here is your "F2" exhaust:
Honda CBR929 CBR954 Bolt on Slip on Exhaust System Taking Off 2001 CBR929RR New | eBay
If you want more power, that means a better (less restrictive) exhaust and that means you should rejet.
lanbrown is offline
Muffler/Can removal question ky0u General Discussion 4 05-19-2012 12:21 AM
Vintage Honda Muffler Question MuscatGreen General Discussion 0 09-02-2008 9:43 PM
Exhaust/Muffler question dgux General Discussion 2 10-28-2007 10:06 AM
need d+d show n go muffler for 900rr mblackwood123 Wanted 0 06-03-2007 5:29 AM
Muffler compatibility 929rr v 900rr Chiung Honda FireBlade 4 06-26-2003 6:56 PM
