MORE HELP NEEDED PLEASE PC3!!! - Honda Motorcycles - FireBlades.org
post #1 of 11 Old 04-04-2004, 12:29 PM Thread Starter
as you have read in my previous thread...the PC3 is set-up and running sweeeeeeet...
...how easy is it to put the stage1 std bike map on the bike if/when i put the std can back on for "stealth" mode?
do i need to delete the old map or just overload the new one onto it????
step by step please
as always any/all help gratefully recieved
jonnyboy is offline
post #2 of 11 Old 04-04-2004, 12:31 PM
Re: MORE HELP NEEDED PLEASE PC3!!!
just load the new map into the PCIII program on the computer, hit "upload all". No need to delete the previous map, the new one will overwrite it.
Sirkbac is offline
post #3 of 11 Old 04-04-2004, 8:27 PM
Zeeman's Avatar
Quoted: 4 Post(s)
Reputation Power: 22
Or get yourself an old palm, and the associated cables and it's even easier.
Z...
You're f%#&king up my Chi...
Zeeman is offline
post #4 of 11 Old 04-05-2004, 4:53 PM Thread Starter
thanks guys
jonnyboy is offline
post #5 of 11 Old 04-05-2004, 6:08 PM
Make sure to calibrate your throttle position sensor while you're at it.
luvtolean is offline
post #6 of 11 Old 04-05-2004, 6:12 PM
how do you do that?
Sirkbac is offline
post #7 of 11 Old 04-05-2004, 7:17 PM
Originally Posted by Sirkbac
how do you do that?
Read the instructions . . .
abtech is offline
post #8 of 11 Old 04-05-2004, 7:53 PM
Always been bad at keeping those things. Will have to look tonight.
Sirkbac is offline
post #9 of 11 Old 04-05-2004, 7:57 PM
Hint: It isn't available until the ignition is switched on, then look under utilities . . .
abtech is offline
post #10 of 11 Old 04-06-2004, 9:29 AM
how do you do that?
Like Abtech hinted to, click on 'Utilities', then on 'Set Throttle Position'.
A window will appear with TP Closed and TP Open (with values next to each).
With throttle in it's off position, click TP Closed button.
With throttle twisted all the way, click TP Open.
These set the Power Commander's full range of your throttle.
When done, the TP Closed window should display (0) with no throttle,
and TP Open should display (100) when throttle is wide open.
SuperDave is offline
post #11 of 11 Old 04-06-2004, 2:36 PM Thread Starter
that was the first thing i did when i put the map on it
it was only getting 95% at first
100% after easy to follow on screen prompts
jonnyboy is offline
Palm OS & PC3 EatnAsphalt Honda FireBlade 8 04-04-2004 9:01 PM
PC3 spillover Honda Naked Sportbikes 6 03-09-2004 2:13 PM
PC3 for Euro 929..? Fire929blade Honda FireBlade 5 01-03-2004 11:12 AM
PC3 vs. moisture.. Fire929blade Honda FireBlade 3 06-20-2003 11:00 PM
