Oil window on 929RR - Honda Motorcycles - FireBlades.org
post #1 of 15 Old 04-05-2004, 1:27 AM Thread Starter
Oil window on 929RR
Well after replacing the left side stator cover with new gasket and silicone safe sealant I've noticed my oil level to be really low. Topped up the oil after replacing the cover (bike was on a swingarm stand) so it was level. Oil level was good then went out riding for a bit and noticed hardly any oil through the oil window. Motor doesn't seem to be burning oil (blue smoke) or leaking anywhere. Although I should pull the fairing out and check to see if its leaking on the bottom of the stator cover and dripping into the inside of the bottom fairing. No fresh oil drips/leaks on the ground either.
Low oil pressure light has not come on during riding.
Question is: How accurate is the oil window??? I know to check oil you supposed to start it up for couple minutes then switch engine off, let it sit for abit and tilt it so it sits upright then check the oil window as specified in the owners manual.
Question 2: When bike is stone cold should the level of oil be visible in the window if its sitting on the kickstand????
Thanks for any help or info
JWHT is offline
post #2 of 15 Old 04-05-2004, 1:32 AM
Re: Oil window on 929RR
After filling it, when you run the bike, the engine takes up some oil, just fill it back up again, it is normal.
Tavish is offline
post #3 of 15 Old 04-05-2004, 1:36 AM Thread Starter
Yes thats true but how much oil does our bikes usually eat up??? I probably have put on maybe 200km if that. It was between the upper and lower marks.
JWHT is offline
post #4 of 15 Old 04-05-2004, 1:38 AM
After an oil change on mine, I fill up accordingly and then after running the engine a bit, if you look in the window, you can barely see any oil, if any.
Tavish is offline
post #5 of 15 Old 04-05-2004, 1:46 AM
Your first mistake was checking it on a stand...the bike may look level but your oil pan isn't...find level ground take it off the stand...hold it level(best if your buddy helps you)...then check it...if its low, add very little at a time. If you changed just the oil...3.2 quarts is fine...oil and filter 3.7 and you are on the money, just in case you lost your owners manual or can't find the specifications section in it.
iridelikeagirl is offline
post #6 of 15 Old 04-05-2004, 2:04 AM
NinerPilot's Avatar
Reputation Power: 25
And make sure you dont have the bike running when you check it. (You didnt specify)
Chris
NinerPilot is offline
post #7 of 15 Old 04-05-2004, 2:10 AM
iridelikeagirl has it right.
Joel is offline
post #8 of 15 Old 04-05-2004, 3:15 AM
Chris
Yes he did. Read it again.
Nick the Quick is offline
post #9 of 15 Old 04-05-2004, 3:19 AM
NinerPilot's Avatar
Doht, nevermind...
Chris
post #10 of 15 Old 04-05-2004, 12:27 PM Thread Starter
Great thanks for all the info and help everyone You people are very helpful and have good explanations.
My friend had mentioned something about oil level on the swingarm stand yesterday, he was saying cause the engine is already tilted forward and it may give a false reading. K guess i'll need a buddy to hold it up as you guys mentioned.
Well I'll be checking it today and will check for any leaks first and ill let all of you know the situation.
JWHT is offline
post #11 of 15 Old 04-05-2004, 4:19 PM
crazycuRRie's Avatar
Send a message via MSN to crazycuRRie
Why would tyou use silcone on a gasket fitted part
WSMC 954
Sponsor: Mach 1,Chicken Hawk Racing, LP USA, Suzuki Motor Corp.
crazycuRRie is offline
post #12 of 15 Old 04-05-2004, 7:20 PM Thread Starter
Silicone must be put on the wire harness that goes in to the stator cover. You don't have to but why waste time and not do it only to find it starts seeping or leaking oil right? I didn't put silicone on the whole surface of the cover as the gasket is good enough to seal it.
UPDATE: I did have a look at the stator cover this afternoon and no leaks and did have the bike upright and added more oil. Thanks again fellow members
JWHT is offline
post #13 of 15 Old 04-05-2004, 7:35 PM
When you drain the engine and replace the filter, the oil doesn't fill the filter until you run the engine. If you aren't counting liters and using the sight glass (while the bike is level and not on a rear stand ), then the level will permanently drop once you run the engine for a couple of minutes. Once it drops and then is shut off, wait about 5 minutes and top it to the correct level . . .
abtech is offline
post #14 of 15 Old 04-06-2004, 2:44 PM
as adove
jonnyboy is offline
post #15 of 15 Old 04-06-2004, 3:45 PM
Sponsor
SilverBullet's Avatar
Reputation Power: 22
You won't see any oil in the window while on the kickstand.
SilverBullet is offline
oil filter question... monkey Honda FireBlade 8 04-01-2004 1:46 PM
Another oil thread! deez Honda FireBlade 3 09-22-2003 9:42 PM
How to change oil on a 954RR? just_john Honda FireBlade 8 07-02-2003 2:27 PM
929 early oil change recommendations Mavic Honda FireBlade 1 05-28-2003 5:26 PM
