How do I get the alternator rotor off the crank '01 929? - Honda Motorcycles - FireBlades.org
 3Likes
  • 1 Post By MrPickwick
  • 1 Post By mika_u
  • 1 Post By mika_u
post #1 of 5 Old 04-15-2017, 6:44 PM Thread Starter
Quoted: 2 Post(s)
I don't have the Honda tool and have been trying to use a conventional gear puller-I've got a lot of tension on it, but it won't budge...I even tried a propane torch to expand it while puller is installed with tension! The reason I'm doing this is because I had dropped the bike and broke a small chunk out of the crank case where the side cover mounts. I had it glued in place with JB Weld, but oil eventually gets through, so I want to try to solder it in place and the rotor is in the way. If someone knows of a better oil-resistant glue I can use to get the chunk of aluminum back in place.
Jeffy1691 is offline
post #2 of 5 Old 04-16-2017, 2:05 AM
Quoted: 487 Post(s)
Re: How do I get the alternator rotor off the crank '01 929?
Hi, once you have got the flywheel bolt out, you will need a rotor tool, its actually just a bolt that will turn into where the rotor bolt has come out of, as it turns in and tightens up ,just tap the end of the bolt and that will release the flywheel,there are different types on E-bay,have a look at this one.
20mm PULLER TOOL for ROTOR STATOR FLYWHEEL FireBlade Honda CBR900RR CBR929RR 954 | eBay
And this is the bolt I used on my CBR400rr
DSCF0869.JPG‎
IanDoohan likes this.
MrPickwick is offline
post #3 of 5 Old 04-16-2017, 9:16 AM
Quoted: 33 Post(s)
Or just use a impact gun with the flywheel puller that is actually a bolt. It will pop right of. I use a oil cooler bolt from a 954 since i have few spare ones of them and actually a spare stock engine disambled. It has the right threads and will do the job fine.
MrPickwick likes this.
mika_u is offline
post #4 of 5 Old 04-16-2017, 3:43 PM
Quoted: 696 Post(s)
Reputation Power: 102
Nice cheat!
IanDoohan is offline
post #5 of 5 Old 04-16-2017, 4:11 PM
Quoted: 33 Post(s)
Originally Posted by IanDoohan View Post
Nice cheat!
Came from a need 😂Had lost the puller and the oil cooler was disambled besides the motor....
mika_u is offline
Help Please, I have turned my crank rotor/starter clutch Graham600RR Tools / Garage / Paddock 8 06-08-2013 12:01 PM
Removing crank position rotor on a Honda CBR 600RR engine JessC Honda CBR 600 2 11-29-2010 12:13 PM
954 alternator into a 929 1ccwit Honda FireBlade 4 03-23-2010 8:59 PM
