Clock and Trip resetting - Honda Motorcycles - FireBlades.org
 1Likes
  • 1 Post By CBR929RRY
post #1 of 6 Old 05-03-2017, 9:57 PM Thread Starter
Hi, I am new to this site, but not to riding. I have already searched and reviewed previous posts on this matter. I didnt want to reply to an old thread.
I have a 03 954. I have the same problem where everything resets when the bike is shut off. I located the 2 big plugs on the right side of the fairing. I have 12v on both sides of the plug on the red and orange wire with the bike off. However the same wire under the seat has no power. When the bike is on I get 0.6v. There is a fuse under the wire that is good. All other fuses are good.
Everything was fine untill I changed the spark plugs. Dont know if this was due to it or not. Near the right spark plug there was a small 2 wire plug. 1 wire was about to break. So I fixed it. 1 side of the plug has 1 green wire and 1 orange wire. The other side has a Orange/black and white/black wire. It goes into the main harness. After putting everything back together is when I noticed the clock problem. I really dont want to cut open the harness. Any help is appreciated.
CBR954Honda is offline
post #2 of 6 Old 05-04-2017, 4:17 AM
Quoted: 17 Post(s)
Reputation Power: 8
Re: Clock and Trip resetting
Looks like you might have already answered your own question...
Doublecheck your handywork since the problem did not appear until you tinkered with the bike. Take it all apart again and check/confirm that all of the harnesses and wiring that you unplugged/fixed are still intact and properly secured, etc.
Make sure that your battery terminals are not loose.
How old is the battery btw? It's possible that a battery "going bad" will cause similar electrical gremlins to appear (trip meter resets each ride, etc).
The only 2 wire harness on the right side of the bike that comes to mind at the moment (I'm sure there's another 2 wire harness or two in that general vicinity) is the "pulse generator" and from what I recall, with that wire harness left unplugged the bike will experience a "no start" condition and that doesn't appear to apply to your specific situation.
It might not be a bad idea to get your hands on a copy of the official factory service manual and consult the wiring diagram so you can hammer out the details of that circuit you were asking about (someone might have posted a copy of the electrical wiring diagram on this message board before if you haven't already tried running a search for it btw).
G'luck troubleshooting !
-'02 Silver/Black CBR 954RR
-'06 Black/Metallic Gray RC-51
-'11 Graphite Black CBR 1000RR
(sold)
-'08 Pearl Orange CBR 600RR (sold)
COBRA90GT is offline
post #3 of 6 Old 05-04-2017, 8:13 AM Thread Starter
Guess I forgot to mention the battery was replaced last year and I have no problems starting. I have taken it back apart thinking it was the wire I fixed, untill I did research that suggests to me that the wire has nothing to do with it. The 2 wires are covered in black plastic and run up toward the left side of the bike.
I have looked to make sure everything is plugged in. I don't see anything unplugged.
post #4 of 6 Old 05-05-2017, 4:24 PM
Quoted: 44 Post(s)
Clocks and trip meter is stored in RAM, which means if you loose battery power you loose that info.
This is usually caused by a wiring issue, bad grounds come to mind. Orange/green wire sounds like to an indicator.
Don't know about black/white. How thick was it?
Look up where your power and ground wires go from the cluster, make sure they are not effected.
IanDoohan likes this.
CBR929RRY is offline
post #5 of 6 Old 05-08-2017, 6:54 AM Thread Starter
The wires look to be 18-22 gauge. Not sure what it goes to.
Do you really think its a ground issue considering the wire under the seat does not have power? Seems like the issue is between the gray plug and battery.
post #6 of 6 Old 05-09-2017, 8:27 PM Thread Starter
I finally had some time to work on the bike with light outside. Here is what I have...
First the wire under the seat that I tested was not the same wire as the plug. Under the seat was green wire with red stripe and the gray plug was red with green stripe. Not sure where exactly the right wire is at under the seat.
Next the 2 wire plug that I fixed runs under the forks to what looks like a valve or something. It has 2 hoses, 1 on each side of it. 1 hose goes between the first 2 spark plugs on the block and the next hose goes between the other 2 plugs.
I cleaned the gray plug with wd40 . Tested 12 volts on each side of the plug. Turned the key on and set the time. Turned it off for 5 minutes. Turned key back on and clock reset again. I put the bike back together and started the bike. Set the clock again and let it run for a couple of minutes. Turned it off and ate dinner. Turned the key to on and the clock is showing the time for now. So dont know what is going on or if it will even stay with the time or not. Very confused. Before I changed the spark plugs I didnt have any problems. I didnt touch any grounds 😕.
Clock keeps resetting...help!!! CBR_954_RR Honda FireBlade 38 02-20-2017 7:19 AM
Clock/trip resetting Mitch2651 Honda FireBlade 4 07-09-2014 10:46 AM
VTX trip odometer resetting itself.... nittfan1980 Honda Cruisers 1 04-15-2011 2:45 PM
CBR 954 Clock resetting paulraf Honda FireBlade 7 02-26-2011 2:49 PM
954 Clock and Trip meter reset magic Honda FireBlade 3 01-19-2004 6:22 PM
