Fork preload and compression adjustment - Honda Motorcycles - FireBlades.org
post #1 of 5 Old 05-21-2017, 12:19 AM Thread Starter
Quoted: 2 Post(s)
Hey guys, been redoing my fork seals and cleaning up the forks. Just curious as to what your settings for the pre load adjuster and bottom compression are? I'm a pretty big boy, and my air gap is around 112mm, with 10w suspension oil, I cant seem to find the default factory setting in the shop manual or the haynes manual. Also if anyones curious in the first picture my dad made a wood lathe out of wood hahahaha
Pics
Artichoke93 is offline
post #2 of 5 Old 05-21-2017, 11:03 PM Thread Starter
Quoted: 2 Post(s)
Re: Fork preload and compression adjustment
Bump anyone? I understand there is a procedure concerning rider sag, I was just curious if there was a default setting I could base my adjustments off of.
post #3 of 5 Old 05-22-2017, 10:09 AM
Quoted: 252 Post(s)
Reputation Power: 10
Since you're doing fork seals, why not update the springs? Racetech's website has a spring calculator, you can input your bike (I don't see it listed)and your weight and it will recommend a spring rate for you.
You may want to a also have a look at the rear spring rate also.
I saw a really big guy the other night on a GSXR. He had an extended swingarm and a shorty exhaust, but was obviously using the stock springs. It was a sad sight to see. He had no idea how unsafe that bike was for him to ride like that.
-My 06 Fireblade Build Thread
-Her 02 CBR600F4i Custom Suspension
-My 07 CRF230F sold
-My 97 XR100
-07 CRF50F son's
-92 CB750 She lets me ride it, Jetted
-13 CRF110F, 01XR50 Daughter's
Jaybird180 is offline
post #4 of 5 Old 05-26-2017, 7:27 PM
Hi here's a great you tube on rider sag settings.
hope this should help
rjhill is offline
post #5 of 5 Old 05-27-2017, 1:57 AM
Quoted: 696 Post(s)
Reputation Power: 102
Here's a Sport Rider recommendation. These are only a suggestion. I see you said you're a big dude, so unless you've replaced your OEM springs with some 1.0's or stiffer the front will still feel squishy, and you won't get the proper sag. My 96-99 manual has a suggested initial setting for the adjustments as well in the beginning of the manual, I just don't have a picture of it. This article only includes the 96-97, but here's the link anyway:
Suggested Sport Bike Motorcycle Suspension Settings | Sport Rider
IanDoohan is offline
Fork Compression adjustment question (929) OutBreak Honda FireBlade 0 01-29-2016 3:11 PM
cbr 929 lack of preload adjustment. nelly929 Honda FireBlade 21 10-16-2013 2:30 PM
Preload adjustment... RidAnyThatRuns Honda CBR 600 18 07-03-2011 11:03 AM
Sag and Preload adjustment Cliff Honda FireBlade 4 07-15-2010 7:05 AM
Preload adjustment FHL Honda FireBlade 5 11-26-2004 3:02 PM
