Fuel cutoff relay clicking - Honda Motorcycles - FireBlades.org
post #1 of 8 Old 05-25-2017, 9:54 PM Thread Starter
Quoted: 4 Post(s)
Reputation Power: 9
Bike will not start, when key is in on position the fuel cutoff relay only clicks and pump will not prime. Hooked up known good fuel pump and same condition, no priming. Tried to test relay per manual but could not 100% verify....not enough hands to touch all connectors and hold to 12V power source all at same time.
Not sure of ot matters but I dont have the stator hooked up at this time. Hahahah almost forgot 02 954, sometimes I even amaze myself.
ande6009 is offline
post #2 of 8 Old 05-25-2017, 11:54 PM
Quoted: 17 Post(s)
Reputation Power: 8
Re: Fuel cutoff relay clicking
Checked the fuse (IIRC, 30amp?) that sits in the starter relay solenoid, correct?
Other fuses checked out OK as well (?) and of course the engine start/stop switch is in the "run" position too, right ? Just to doublecheck...
If the above is all good, it's time to break out the wiring diagram/shop manual and start tracing connections/wires (grounds, etc). G'luck & let us know what the culprit was !
-'02 Silver/Black CBR 954RR
-'06 Black/Metallic Gray RC-51
-'11 Graphite Black CBR 1000RR
(sold)
-'08 Pearl Orange CBR 600RR (sold)
COBRA90GT is offline
post #3 of 8 Old 05-26-2017, 8:39 AM
Heeza Y Zasch
unslow1's Avatar
Quoted: 386 Post(s)
Reputation Power: 59
I'm confused... so what's your main problem?
you said:
Originally Posted by ande6009 View Post
Bike will not start
but:
Problem #1 solved Now onto Problem #2 :
Stop. Does your fuel pump relay click ON... then 2-3 seconds later click OFF? It should. It's job is to "prime" the FI system (build pressure for starting) by sending a signal to the fuel pump, then interrupt signal 2-3 seconds later. We'll need to know if the fuel pump relay is doing that, so we can properly and efficiently troubleshoot the issue you're having.
Additionally, ensure all other (including the Fuel Pump Relay) relays are operating properly (can attempt selective interchange with Fan Relay and Headlamp Relay... and don't forget about the "4th relay" next to the fusebox). Your BAS (bank angle sensor; located between the gauge cluster and headlight assembly), Clutch safety switch (two wires on the clutch perch), and Sidestand safety switch (another two wire connector in the vacinity of... yup. you guessed it, the sidestand) will all affect a non-starting machine. Check those spots, clean & reassemble as necessary, and check them off the list of potential problems.
If I was working on your machine, the first thing I'd do is put that starter back in. No sense troubleshooting a "non-starting" issue if it has non-starter
Keep us posted
unslow1 is offline
post #4 of 8 Old 05-27-2017, 7:06 PM Thread Starter
Quoted: 4 Post(s)
Reputation Power: 9
I feel like an idiot. I swapped barteries and attempted to crank it , and for some reason after the fourth bump of starter the fuel pump started priming. She's alive !
ande6009 is offline
post #5 of 8 Old 05-28-2017, 2:41 PM
Gunk's Avatar
Quoted: 496 Post(s)
Reputation Power: 23
So a flat battery
Gunk is offline
post #6 of 8 Old 05-28-2017, 3:14 PM Thread Starter
Quoted: 4 Post(s)
Reputation Power: 9
Im not sure why battery was no working. It has 12.7V.....oh well new battery and all is good. Guess pump needed 14V to kick start into gear after sitting for 2 years.
ande6009 is offline
post #7 of 8 Old 05-28-2017, 3:38 PM
Quoted: 198 Post(s)
Reputation Power: 25
Battery voltage alone doesn't mean much, what was it while under load? You can test a battery and the static voltage can be good, place it under a load and the voltage drops.
lanbrown is offline
post #8 of 8 Old 06-13-2017, 7:45 PM Thread Starter
Quoted: 4 Post(s)
Reputation Power: 9
I didnt check it under a load, in retrospect I guess I should have checked it before swap......I learned another piece of the "diagnostic pie" today. Thanks.
ande6009 is offline
DIY: CBR400 NC23 Fuel Cutoff Relay Repair With Schematic gogamoto Honda CBR400RR 0 12-12-2012 1:19 PM
Clicking noise from starter relay Hawkes Honda CBR400RR 4 01-10-2012 12:45 PM
Fuel pump relay 04 RC Gariepy Honda RC51 1 09-20-2011 9:05 PM
929RR Fuel pump / relay clicking Ghines1279 Honda FireBlade 11 09-05-2010 7:21 PM
Fuel cut-off relay fez_94 Honda FireBlade 1 07-01-2010 3:13 PM
