07 1000rr , dies when put in gear - Honda Motorcycles - FireBlades.org
 1Likes
  • 1 Post By Jaybird180
post #1 of 6 Old 06-26-2017, 5:17 AM Thread Starter
Hi guys I've searched already an alot of the problems are similar .
Kick stand switch is already bypassed from previous failure.
Just replaced lower crank case .
Due to lay down
Problem is bike dies when putting it into gear from N .
Revs an runs great ...
Heard that clutch plates may be sticking .
I follwed the manual for the clutch oiled an replaced as I pulled out . basket nut is torqued to spec . I have the clutch flat spring an relief spring and plates in correctly .
Also heard it might be a tilt switch or the clutch interlock (lever switch) . only heard those when releasing the lever it dies ..
Mine just flat out dies when selector pushed
Unsure as to what it may be .
Can someone provide me with a good clutch build post ?
Aktrue is offline
post #2 of 6 Old 06-26-2017, 11:12 AM
Quoted: 254 Post(s)
Reputation Power: 10
Re: 07 1000rr , dies when put in gear
Can you rotate the rear wheel with the bike in gear and cause the engine to spin? If so, then you need a wiring diagram to solve your enigma.
-My 06 Fireblade Build Thread
-Her 02 CBR600F4i Custom Suspension
-My 07 CRF230F sold
-My 97 XR100
-07 CRF50F son's
-92 CB750 She lets me ride it, Jetted
-13 CRF110F, 01XR50 Daughter's
Jaybird180 is offline
post #3 of 6 Old 06-26-2017, 5:41 PM Thread Starter
When in neutral the basket spins free
When in gear you can hear the basket trying to grab
When you start the bike you can start it in neutral without engaging clutch lever .
As soon as you engage the clutch an kick it into gear it shuts off as if the kickstand was doing it .... But I have it jumpered..
I dont know if my jumper failed or if there's another switch
Aktrue is offline
post #4 of 6 Old 06-27-2017, 11:14 AM
Quoted: 254 Post(s)
I'll try to remember to take a look at mine, but I don't recall seeing any electrical connectors or switches at the perch. In either case, I doubt it would kill the bike.
Anything on the MIL?
Greekboy likes this.
-My 07 CRF230F sold
-My 97 XR100
-07 CRF50F son's
post #5 of 6 Old 06-27-2017, 7:40 PM Thread Starter
Found it it was a failing interlock for the lever bypassed an all good . over looked but fixed
Aktrue is offline
post #6 of 6 Old 06-28-2017, 9:04 AM
Quoted: 254 Post(s)
I guess you know by now that there is an electrical connector at the clutch perch.
I don't understand your diagnosis and fix but I'm glad you got it working. Why so many bypasses?
-My 07 CRF230F sold
-My 97 XR100
-07 CRF50F son's
2001 CBR 929 RR dies when put into gear! Fukwon187 Honda FireBlade 5 01-15-2011 10:09 AM
bike dies when put in gear, bit of advice mechanoid Honda CBR400RR 5 12-04-2009 1:18 AM
02 CBR 954 dies in First Gear!!! Please Help jlopez84 Honda FireBlade 4 08-19-2009 11:33 AM
2005CBR1000rr Dies when i put it in gear. Gonzo1000rr Honda FireBlade 8 12-16-2008 10:19 AM
dies when put in gear jimmydean Honda FireBlade 6 05-10-2008 8:09 PM
