03 954RR battery issues? - Honda Motorcycles - FireBlades.org
 12Likes
  • 4 Post By lanbrown
  • 1 Post By COBRA90GT
  • 1 Post By unslow1
  • 2 Post By lanbrown
  • 1 Post By EAY1991
  • 1 Post By IanDoohan
  • 2 Post By EAY1991
post #1 of 11 Old 06-28-2017, 10:43 AM Thread Starter
Hi all,
I just bought a 2003 CBR954RR with less than 30 thou km on the odometer. I borrowed it for a day to test it out and it ran perfect, aside from the speedometer reading '0' (already ordered the sensor online), and the neutral light not working for now (fixable for sure). On the day i brought it home, I stopped to fill her up with gas. Tried to start her after but the battery seemed discharged. Volts were reading around 11.5-12v on the meter. Had to push start her manually. Also noticed she was a wee bit more sluggish below 3k RPM, something that wasn't present when I test drove it.
Stopped to grab dinner a few kilometers from my house after around 40 minutes of riding, and she wouldn't start again. Once she fired up after the trusty push jump start, I noticed she never got above 13.5v on the meter. She was also idling rough at stops, threatening to stall, with the idle set at a tad above 1k RPM. I was able to get home, but she died right at my driveway. Stalled out since I was coasting clutch in to park.
Could this be a battery issue? Rectifier or stator? Can the lack of juice affect my engine performance in any way?
Any help would be appreciated!
EAY1991 is offline
post #2 of 11 Old 06-28-2017, 10:53 AM
Quoted: 198 Post(s)
Reputation Power: 25
Re: 03 954RR battery issues?
You need to diagnose the entire charging system. A bad charging system can kill a battery. So just replacing parts is not the answer as you could end up replacing things again.
lanbrown is offline
post #3 of 11 Old 06-28-2017, 11:01 AM
Quoted: 17 Post(s)
Reputation Power: 8
It's possible the battery itself is "flat," meaning it will show a "normal" voltage when you put a multimeter to it, but the battery won't actually have enough juice to start/crank the bike over (hence your recent push starts).
Any idea how old the battery is or if the previous owner has drained that battery down a few times?
Definitely check/verify the entire charging system itself as well while you're at it but I would start with load testing that battery...g'luck !
kahlilj likes this.
-'02 Silver/Black CBR 954RR
-'06 Black/Metallic Gray RC-51
-'11 Graphite Black CBR 1000RR
(sold)
-'08 Pearl Orange CBR 600RR (sold)
COBRA90GT is offline
post #4 of 11 Old 06-28-2017, 11:05 AM
Heeza Y Zasch
unslow1's Avatar
Quoted: 388 Post(s)
Reputation Power: 59
In addition to @lanbrown , prepare yourself to replace battery, stator, stator cover gasket, and Regulator/Rectifier. I highly recommend OEM, Rick's, Mosfet, or other replacement that meets/exceeds factory QUALITY parts.
954s (especially with that mileage/kilometerage) are due for these parts to wear out anyway As well as CCT, relays, connectors, and other associated electrical issues.
Please keep us posted
IanDoohan likes this.
unslow1 is offline
post #5 of 11 Old 06-28-2017, 11:12 AM Thread Starter
I'll be looking into that in the morning (Philippine time now is 10:10pm) with my battery tender to check the status of the battery. As far as I know, the bike was a daily and the previous owner just replaced the battery a month or two ago.
EAY1991 is offline
post #6 of 11 Old 06-28-2017, 11:14 AM
Quoted: 198 Post(s)
If the battery is new, then you have a charging system issue and that can kill a battery. Check the stator, the R/R and all of the electrical connections/connectors. Anything that looks bad or fails, replace it. Also, at times, a R/R can pass the test but it is still faulty; I've had that issue before.
kahlilj and EAY1991 like this.
lanbrown is offline
post #7 of 11 Old 06-28-2017, 11:15 AM Thread Starter
Yup! Got those lined up already. OEM or, if I have the spare cash, Ricks or Mosfet regulator, and OEM stator and associated parts. Gotta do it through eBay since 954rr parts are very rare in the Philippines. There are only less than 15 of them in the entire country!
The rest of the electrical components will be done in one go at a shop I frequent. Hopefully that'll fix my missing neutral and sometimes missing fuel light. haha
unslow1 likes this.
EAY1991 is offline
post #8 of 11 Old 06-29-2017, 12:52 AM Thread Starter
Okay, so we narrowed it down to the starter motor. Battery charges well and is good, also the stator and rectifiers are okay. Replace gaskets but that's okay.
Still waiting to see if it's the entire motor or certain parts in it.
EAY1991 is offline
post #9 of 11 Old 06-29-2017, 1:29 PM
Quoted: 733 Post(s)
Reputation Power: 102
The starter won't give you the running issues you described. You may still have a charging issue. Here is a good reference to test and diagnose the system:
http://www.electrexworld.co.uk/acata...P-PMG-&-RR.pdf
With all the FI electronics on the bike, a weak system, or a system that begins to fail once warm could possibly give you the running/low rpm issues. Just make sure you're certain. Hate to see you get far from home and be stranded.
kahlilj likes this.
IanDoohan is offline
post #10 of 11 Old 06-29-2017, 9:18 PM Thread Starter
Thanks for the tip. Also forgot to mention that my mechanic explained to me that the retardedly short race pipe is responsible for the sluggish feeling below 3k RPM. Ordering a longer slip on soon since the one on the bike now is basically an open pipe with a gutted akra.
EAY1991 is offline
post #11 of 11 Old 07-07-2017, 2:27 PM Thread Starter
Update!
Bike runs really well now. Turns out the issue was the carbon brush and armature in the starter. Replaced those and have had nothing but kilometers of good riding for the past two days
kahlilj and 954Kevin like this.
EAY1991 is offline
battery issues Meddy62 Honda FireBlade 5 04-29-2017 4:55 AM
Battery issues.. i think? greyg00se19 Honda CBR 600 6 10-04-2008 7:21 PM
battery issues help 03degrassi Honda CBR 600 2 07-27-2008 9:23 PM
battery issues please help 03degrassi General Discussion 1 07-27-2008 7:55 PM
Battery Issues sgracida Honda FireBlade 12 09-17-2007 2:28 PM
