I need some help diagnosing/fixing - Honda Motorcycles - FireBlades.org
 9Likes
  • 2 Post By Gunk
  • 1 Post By amancalledrob
  • 1 Post By Gunk
  • 2 Post By amancalledrob
  • 1 Post By Gunk
  • 1 Post By BenelliBlade
post #1 of 12 Old 07-07-2017, 7:25 AM Thread Starter
Quoted: 10 Post(s)
Reputation Power: 6
Hi all
I've run into my first mechanical issues with my RR-X. Recently it's been using a bit of oil (it's needing a top-up about every 1000 miles) and yesterday I went out for a blat and at first everything was fine but later in the ride it started to feel a bit low on power - felt a bit like the fuel starvation you get when it's time to switch to reserve tank - and by the time I got home she was feeling pretty gutless.
Tomorrow I'm going to remove and clean the carbs. I've never done this before so what should I look out for?
amancalledrob is offline
post #2 of 12 Old 07-07-2017, 9:02 AM
Quoted: 487 Post(s)
Re: I need some help diagnosing/fixing
Hi, the overhaul of the carbs is in the manual, but before you take them off take out the plugs and have a look at them, see if their the right colour, and with the carbs still on do a compression test(spark plugs still out) and then perhaps the carbs, if the compression test is alright your valve clearances should be within scope, just follow the manual for the carb clean
MrPickwick is offline
post #3 of 12 Old 07-07-2017, 10:58 AM
Gunk's Avatar
Quoted: 509 Post(s)
Reputation Power: 24
I'd do one carb at a time,you'll be less likely to lose bits or mix up jets (inner jets are different to the outers)
BigdaddyPaz and MrPickwick like this.
Gunk is offline
post #4 of 12 Old 07-07-2017, 12:25 PM Thread Starter
Quoted: 10 Post(s)
Reputation Power: 6
Thanks for the tips guys. Valves were done just recently at 38000 miles, she's on 45899 now. Need her tip top for the Nurburgring at the end of next month!
MrPickwick likes this.
post #5 of 12 Old 07-10-2017, 2:55 PM Thread Starter
Quoted: 10 Post(s)
Reputation Power: 6
Quick update: went out Saturday morning and spent 25 on a can of carb cleaner, a can of compressed air, gloves, wipes etc then sat down in the garden in the sun to start The Big Clean
...which soon turned into The Big Disaster as the first float bowl screw I came to was seized solid. I sprayed it liberally with WD40 and thought I'd check the pilot screw settings while I waited for it to soak in. The second pilot screw was also seized and the half the head snapped off the moment I tried to undo it.
So I walked the carbs up to my local bike shop to be ultrasonically cleaned. 100 and I pick them up tomorrow. What a ballache
post #6 of 12 Old 07-10-2017, 3:06 PM
Gunk's Avatar
Quoted: 509 Post(s)
A leaking petcock can also cause running problems, might be worth checking especially with the tank off the bike.
Gunk is offline
post #7 of 12 Old 07-10-2017, 3:17 PM Thread Starter
Quoted: 10 Post(s)
Reputation Power: 6
Thanks, that's a good shout. I think I found at least part of the problem - the clips securing the carbs to the inlets weren't very tight and would have been allowing air in
post #8 of 12 Old 07-13-2017, 11:10 AM Thread Starter
Quoted: 10 Post(s)
Reputation Power: 6
Ok so I've put the bike back together and it's running like a peach! I've set the mixture screws at the stock 2 turns out plus an extra quarter turn for safety as I have a Yosh RS-3 end can.
The bike now fires up with no throttle, which it didn't before. It also picks up the front in 1st on about 90% throttle, which it would previously only do on full throttle and then only if I shifted back in the seat. I haven't balanced the carbs but it doesn't feel like they need it.
It's going on a dyno on Saturday morning so I'll have a look at the fuelling then. I'm very happy indeed
unslow1 and MrPickwick like this.
post #9 of 12 Old 07-17-2017, 12:57 PM Thread Starter
Quoted: 10 Post(s)
Reputation Power: 6
Dyno results are in
I haven't had them by email yet but she made 117.34 at the wheel. Add 10% for the crank figure and it's a very healthy 129ish so I'm very pleased. The fuelling is a bit lean around 4-8k so I'm going to shim the needles up a touch to sort it. It's fine once it's on the main jets
I need a bit of advice on oil use though. When it's on the dyno there's a bit of dark smoke out of the exhaust at the top of the rev range. The bike's only on 46k miles so I don't think it's piston rings and I'm thinking maybe valve stem seals? Has anyone had a similar experience? If so would you recommend a head refurb?
post #10 of 12 Old 07-17-2017, 2:22 PM
Gunk's Avatar
Quoted: 509 Post(s)
It's more likely to be valve guides, personally I would leave it for the time being and just check oil consumption per 1000 miles before you made a decision to tear it apart
amancalledrob likes this.
Gunk is offline
post #11 of 12 Old 07-17-2017, 3:14 PM
Quoted: 53 Post(s)
Dark smoke typically indicates running rich, oil smoke has a blu-ish tint to it. Worn valve guides/seals also show themselves under vacuum (i.e. which pulls oil down the guides) rather than at sustained full throttle, you normally see a puff of smoke after rolling the throttle off and then back on again.
A leak down test would show how well the rings are sealing.
BenelliBlade is offline
post #12 of 12 Old 07-19-2017, 9:39 AM Thread Starter
Quoted: 10 Post(s)
Reputation Power: 6
Thanks guys. I'm off to the Alps next month and coming home via the Nurburgring where I want to push for a better lap time than last year so I really want the bike tip top as I use a lot of over-rev into some of the corners. With that in mind I've booked it in to have the oil use diagnosed. It didn't previously use any oil at all between services so something's definitely changed and I'd like to be certain it's not something that's about to let go in an exciting way if you know what I mean
1995 CBR F3/F2 Need help Diagnosing Problem mtinnin93 Honda CBR 600 6 07-11-2015 5:50 AM
Need help fixing my bike Wellsr40 Honda CBR 600 4 07-24-2014 3:51 PM
Need help fixing my bike Wellsr40 General Discussion 2 07-24-2014 12:51 AM
need help diagnosing problem opey954 General Discussion 3 06-26-2012 1:04 AM
HELP!! fixing fairings naz General Discussion 2 10-11-2010 2:19 AM
