Dynojet PC V on a 954RR - Honda Motorcycles - FireBlades.org
 17Likes
post #1 of 16 Old 07-08-2017, 6:27 AM Thread Starter
ART
Quoted: 2 Post(s)
Has anyone fitted a Dynojet Power Commander V to their 954 FireBlade?
I don't care about the numbers I just want to know about how the bike feels.
I use my Blade as my daily ride as well as on the track and fun rides and at low rpm (below 4,000) it hunts and lurches. Does the PC V sort this out?
Also does anyone know if the Australian model has an O2 sensor which would allow me to use an Autotune as well?
All opinions and experiences are welcome.
20170413_121757.jpg‎
ART is offline
post #2 of 16 Old 07-08-2017, 10:01 AM
Quoted: 33 Post(s)
Re: Dynojet PC V on a 954RR
You can't use the bikes O2 even if aussie model has one. It isn't a wideband wich is needed for autotune. You just need to get a bung welded to the midpipe for the autotunes O2 sensor. Power commander doesn't do anything by itself. It is more about the mapping but with good map it will help a lot to the twitchines etc....
fj1200rj and ART like this.
mika_u is offline
post #3 of 16 Old 07-15-2017, 8:36 PM
Quoted: 5 Post(s)
I Have a PC V fitted to my 954 and had a custom map made at the same time, bottom end felt very twitchy (on/off throttle response) horrible to ride in traffic but above 6000 was arm wrenchingly dangerous like two stroke power band , have now downloaded and installed the Dynojet map for Arrow race exhaust and it's like a different bike totally smooth power now from 2000 all the way up. Feels slower from 6000 up but so much more ride able
so yes i would 100% recommend getting a PC V and find a map you like or for a 150 or so have a custom map made
sapi69 is offline
post #4 of 16 Old 07-18-2017, 4:36 AM
Quoted: 10 Post(s)
Send a message via Yahoo to kahlilj
Yes, this guy did. Did you read this thread?
https://www.fireblades.org/forums/hon...air-ducts.html
See above link, Did you consider getting the Auto Tune feature?
ART likes this.
kahlilj is offline
post #5 of 16 Old 07-18-2017, 5:33 AM
Quoted: 487 Post(s)
As @mika_u says ,wideband and positioning, have a look at this
http://wbo2.com/lsu/LsuInstal.pdf
fj1200rj likes this.
MrPickwick is offline
post #6 of 16 Old 07-19-2017, 8:31 AM
Quoted: 159 Post(s)
Reputation Power: 122
I have a PC III USB that was on the bike along with the Dyno-tune when I bought it. It pulls pretty smooth. One of these days I'm going to disconnect it just so I can see how bad this twitchiness you all speak of is! A PC 5 with auto-tune is an upgrade I would like to make. A friend put one on his R1 and is very pleased with it.
BTW, it looks like you have an OEM mid pipe with a bolt on Micron can, the o2 sensor would be on top of the mid pipe. I don't see it, or the wiring, in your pic so I'm guessing you don't have one installed. See if there is a bung there for one, perhaps someone removed it and plugged the pipe.
MrPickwick likes this.
fj1200rj is offline
post #7 of 16 Old 07-19-2017, 8:48 AM
Quoted: 487 Post(s)
Originally Posted by fj1200rj View Post
I have a PC III USB that was on the bike along with the Dyno-tune when I bought it. It pulls pretty smooth. One of these days I'm going to disconnect it just so I can see how bad this twitchiness you all speak of is! A PC 5 with auto-tune is a upgrade I would like to make. A friend put one on his R1 and is very pleased with it.
Yes as mika_u says the wideband oxygen sensor is more sensitive and with the autotune should make all the difference, as for me my days of "tuning up" are over, even returning my 954 to stock
post #8 of 16 Old 07-19-2017, 8:48 AM
Quoted: 159 Post(s)
Mika, does the Auto-tune o2 sensor fit the OEM bung? Just curious, my mid pipe is aftermarket so I know I will have to have one welded on when the day comes.
fj1200rj is offline
post #9 of 16 Old 07-19-2017, 8:54 AM
Quoted: 159 Post(s)
Yea, me too. I'm just looking to take advantage of modern technology, make my 954 the best it can be, LOL .
fj1200rj is offline
post #10 of 16 Old 07-19-2017, 7:15 PM
Quoted: 33 Post(s)
No clue since my bike is a standard euro model that hasn't a O2. But it actually doesn't matter since there are adapters to use small sensor in big bung and vice versa. My Akra has the small one from factory and dynos use normally large one so we use the adapter since getting titanium welded isn't that simple here.... I don't even remember what size auto tune uses since i haven't one. But friend of mine has it on his 954 and he liked it....
fj1200rj and MrPickwick like this.
mika_u is offline
post #11 of 16 Old 07-19-2017, 7:21 PM
Quoted: 33 Post(s)
When my engine was stock i had a Devil high mount slip-on, smoothened airbox with little bit opened inlets, BMC street airfilter and pc3usb with custom tune and it pulled like a train from idle to limiter. Just need a good tuner...
20140814_130419.jpg‎
kahlilj, fj1200rj and MrPickwick like this.
mika_u is offline
post #12 of 16 Old 07-20-2017, 8:03 AM
Quoted: 159 Post(s)
Good to know, thanks. Small sensor in a big bung, lol, story of my life...
Very nice, 17 HP seems like a really good increase for a slip on, filter and opening the inlets! I think mine was only 149 HP I believe. The PO gave me the dyno sheet, I have it somewhere. I know different dynos can net different numbers, so I may be comparing apples to oranges. Just out of curiosity, the dates are 2 years apart. Did they save your file and were the runs actually 2 years apart. I'm going to try to find mine for comparison. I'm sure the extra 14-15 HP is 'cause you're at around 62 Deg. Latitude. and I'm at 35 Deg., the air is more dense up there at the Arctic Circle, yeah, that's it!
IanDoohan and MrPickwick like this.
fj1200rj is offline
post #13 of 16 Old 07-20-2017, 6:24 PM
Quoted: 33 Post(s)
Noup. Should have clarified that the blue line is the one i was speaking of... 146hp from engine. The red line is a a cammed hicomp motor with full exhaust.... Same motor thought but 2 years later... It even revs 13250 instead of the stock 12k. But the curve is much better with stock motor...
mika_u is offline
post #14 of 16 Old 07-20-2017, 7:06 PM
Quoted: 159 Post(s)
Thanks for the clarification, that makes more sense. I posted last night in a very tired state, when I re-read my post I realized that I was thinking about your readings, and had your numbers in my head. Now that I'm awake I realize that mine was no where near 149hp. In fact, I think it was only in the high 120+hp range. I haven't seen it in about 6 years. I just looked at it and stuck it in a pile somewhere and forgot about it. The only thing I remember for sure is that it was a Dynojet. I'm sure the number would have stuck in my head had I been the one who paid for the dyno tune. High 120's to your 146, clearly I need a different tune. Now I'm wondering if mine was a custom tune or just an off the shelf map from Dynojet. Either way, I guess I shouldn't get hung up on the numbers. It pulls smooth and has all the power I need.
fj1200rj is offline
post #15 of 16 Old 07-20-2017, 7:47 PM
Quoted: 33 Post(s)
I actually could beat many of friends with newer 1000cc bikes and even gen1 Busas from standing launch with the stock motor bike. It is very much harder now since it has few hp less down and when i get it going it pulls the front up at 8k with smaller gears... Doing the same thing now only the newer 1000cc bikes did when i rode against them. Money well spend 😂
mika_u is offline
Dynojet. Just not right!!! Camelhump Honda FireBlade 11 08-11-2013 4:31 AM
RRX Dynojet? Which One?? Camelhump Aftermarket Perfomance Parts Reviews 7 05-16-2013 11:26 AM
954RR - Dynojet PC3, K&N air filter Chuck_V13 For Sale 24 03-24-2012 12:38 AM
Dynojet QS - what's needed? majormods Honda FireBlade 2 01-30-2012 8:57 AM
Dynojet Kookie Vendor / Seller / Dealer Reviews 1 03-16-2004 9:19 PM
