954 crankshaft end play - Honda Motorcycles - FireBlades.org
post #1 of 2 Old 07-24-2017, 11:39 AM Thread Starter
Reputation Power: 7
Picked up a used set of cases and installed the crankshaft today to make measurements and found my end play on the crank shaft is only .002 almost no movement at all in the end play. How do you adjust that it looks almost as if it's built into the case no thrust washer?
Defomx26 is offline
post #2 of 2 Old 07-24-2017, 12:16 PM
Quoted: 33 Post(s)
Re: 954 crankshaft end play
Measure crank pin diameters and order correct bearing shells for it. Crankshaft is between the cases only by the crank bearings and the big bearing at the other end...
mika_u is offline
2002 954 Crankshaft codes & bearings smittypig24 Honda FireBlade 8 03-17-2014 9:25 PM
954 Steering Stem Play/Questions Wac954 Honda FireBlade 0 01-27-2013 8:16 PM
I need the crank end play spec for 929 oconnor Honda FireBlade 2 09-13-2008 3:53 PM
954 front end vs 1000rr front end moron900 Honda FireBlade 8 08-28-2007 11:17 AM
It's Crankshaft!!! ReaperAZ Off-Topic 12 05-24-2005 4:37 PM
