New sleeve in cylinder - Honda Motorcycles - FireBlades.org
 1Likes
  • 1 Post By fj1200rj
post #1 of 14 Old 08-11-2017, 9:40 PM Thread Starter
Quoted: 4 Post(s)
Reputation Power: 9
Does anybody know where or who can dobthis? I'm in FL, we have local guys but they act like a cast iron sleeve will work in a Japanese sportbike.....lol
ande6009 is offline
post #2 of 14 Old 08-12-2017, 5:03 AM
Quoted: 487 Post(s)
Re: New sleeve in cylinder
There are quite a few threads on here associated , but have a look at this, whats the bike
Motorcycle Cylinder Plating & Replating | U.S. Chrome Corporation of Wisconsin Cylinder Repair Company
MrPickwick is offline
post #3 of 14 Old 08-13-2017, 12:32 PM
Quoted: 749 Post(s)
Reputation Power: 102
What model bike? I had wafer thin cast iron sleeves put in my 93, with 75mm pistons. Ran it for a few years with them, then sold the bike. I guess it depends on the model. Later Blades have the aluminum block bored and then coated. I don't know how a cast iron sleeve put into that set up would effect the really small piston skirts that are coated as well.
IanDoohan is offline
post #4 of 14 Old 08-13-2017, 12:53 PM Thread Starter
Quoted: 4 Post(s)
Reputation Power: 9
03 954 but I also have a 929 I need to sleeve also. My 954 has 1700 miles so bits worth putting a sleeve into. My 929 has 12K, but I love it so I'll sleeve it also
ande6009 is offline
post #5 of 14 Old 08-13-2017, 1:43 PM
Quoted: 33 Post(s)
Get them plated. Stock bores on them aren't plated. It is called alusil and nicasil that they use to plate the bores is tougher...
mika_u is offline
post #6 of 14 Old 08-13-2017, 3:17 PM Thread Starter
Quoted: 4 Post(s)
Reputation Power: 9
So let me get this straight . Nicasil the iron sleeve? Aluminum sleeve? Or no sleeve at all.
I believe I need a new bore from water damage, sitting in cylinder. The wall has corrosion about 1/2 an inch lower than lower ring.
ande6009 is offline
post #7 of 14 Old 08-13-2017, 5:47 PM
Quoted: 33 Post(s)
929 and 954 have hypereutic aluminium sleeves commonly known as alusil. Alusil can be plated with nicasil plating like every other sleeve. Bare aluminium sleeve that has damage to the original nicasil plating, steel sleeve for better bore surface and alusil bore allso for better and tougher wear surface for the bore. My 954 has been bored 1mm oversize and nicasil plated at millenium technologies but i wouldn't recommend using them. U.S. Chrome would be the other choice...
mika_u is offline
post #8 of 14 Old 08-13-2017, 7:27 PM Thread Starter
Quoted: 4 Post(s)
Reputation Power: 9
So steel sleeve is ok as long as it is coated?
ande6009 is offline
post #9 of 14 Old 08-14-2017, 6:18 AM
Quoted: 33 Post(s)
Why do you wan't to put a steel sleeve in it? It can work if Honda has left little reserve to the cooling system but steel conducts heat less then stock aluminium ones and you will allso lose performance wise since with the steel sleeve you will need more piston to wall clearence.... I actually seen one 954 that was for sale and had steel/iron sleeves installed on it with Wiseco pistons but no clue how hot does is run...
I would recommend getting the stock bores fixed or going 1mm oversize on the stock bores...
mika_u is offline
post #10 of 14 Old 08-14-2017, 7:47 AM Thread Starter
Quoted: 4 Post(s)
Reputation Power: 9
I don't want steel sleeves, the local guys I talked to install steel sleeves only. That is why I posted on here. To get an opinion of someone that has delt with this issue before. Boring 1mm over will require new pistons? How much can you bore factory sleeves?
ande6009 is offline
post #11 of 14 Old 08-14-2017, 8:39 AM
Quoted: 33 Post(s)
Depends on the damage the cylinders and pistons have. When bored you will always need bigger pistons...At U.S. Chrome they do recondition stock pistons and bores if they aren't too far gone. So i would give them a call. They did that for a member here and he was happy with the job they did.... The stock alusil can allso be bored 0.25mm oversize and pistons for that you can get from Honda but you would need to find a shop that knows how to work with alusil.
mika_u is offline
post #12 of 14 Old 08-14-2017, 1:15 PM
Quoted: 254 Post(s)
I'm guessing you've already priced a used engine?
-My 06 Fireblade Build Thread
-Her 02 CBR600F4i Custom Suspension
-My 07 CRF230F sold
-My 97 XR100
-07 CRF50F son's
-92 CB750 She lets me ride it, Jetted
-13 CRF110F, 01XR50 Daughter's
Jaybird180 is offline
post #13 of 14 Old 08-15-2017, 7:06 AM
Quoted: 159 Post(s)
Reputation Power: 122
1mm=0.039" so yeah. Even 0.010" requires an oversize bore.
MrPickwick likes this.
fj1200rj is offline
post #14 of 14 Old 08-16-2017, 9:32 AM Thread Starter
Quoted: 4 Post(s)
Reputation Power: 9
Most used engines are $800-$1000 so its worth putting the $$ into, + i know it will be good as new and ready for 50K miles or so.
ande6009 is offline
Swingarm conversion sleeve length? wiffer Honda RC51 2 12-29-2015 3:27 AM
right 954 stuff (cables, start/stop switch, throttle sleeve, aftermarket grip, barend perf0rmance For Sale 7 08-01-2008 3:53 AM
needle bearings and sleeve ??? bjay51d General Discussion 7 02-20-2008 6:57 AM
Micron Sleeve Swap? EatnAsphalt Honda FireBlade 12 01-11-2004 12:58 AM
Honda's got nothing under their sleeve! EVO9 Honda FireBlade 13 09-24-2003 11:44 AM
