Neutral Light stays on - Honda Motorcycles - FireBlades.org
post #1 of 1 Old 08-16-2017, 8:20 AM Thread Starter
Hi all, I realize this may not be the right forum but I thought I would get some more responses here.
So I currently have a 1990 Honda CBR400RR (L) which has an issue with the neutral light. Basically the neutral light will stay on, even when in gear. The only difference being in gear does is very slightly dim the neutral bulb. I changed the neutral switch and the problem still persists.
After a while I realized that if I put down the side-stand, the neutral light will work as it should; on in neutral and off in gear. However, for some reason when doing this if the bike is in gear and the kickstand is down, the kickstand light will turn off if in gear and turn on only in neutral. I unplugged the side-stand cable and again the neutral light works as it should but obviously the side-stand light will not work.
Could this be an issue with the sidestand switch or is it a pinched wire grounding somewhere?
Your assistance would be greatly appreciated
Sbonett is offline
Neutral bulb stays on whilst in gear Sbonett Honda CBR400RR 17 09-01-2016 5:00 PM
Neutral light stays on? cesarsanch2 Honda FireBlade 3 10-23-2013 12:32 AM
94 cbr900rr neutral light stays on... deplacent Honda FireBlade 1 03-31-2010 2:14 PM
1985 honda nighthawk 700sc neutral light stays on crockett General Discussion 4 01-03-2009 9:05 AM
Neutral light stays on DS760 Honda FireBlade 0 07-14-2005 3:03 AM
