Throttle grip help - Honda Motorcycles - FireBlades.org
 2Likes
  • 1 Post By jondog9
  • 1 Post By kahlilj
post #1 of 7 Old 08-21-2017, 7:31 PM Thread Starter
Quoted: 10 Post(s)
Send a message via Yahoo to kahlilj
Throttle grip help
ok so I have a weird situation that happened when I tried replacing my handlebar grips. Replaced the clutch side no problem but when I tried screwing in the bolt on the throttle side, somehow I stripped it. The bolt will turn, but not move in nor out. Any suggestions on how to remove this?
https://app.box.com/s/lt616jcg2vjcv2718ljvhc4a89zlo0o3
https://app.box.com/s/i5xhy3i2dh6ri7vzlorcsg7xcxc2q4xo
https://app.box.com/s/9tvds3w59bh26rigm9x7q2eg5uxvvxo5
kahlilj is offline
post #2 of 7 Old 08-21-2017, 7:41 PM
Quoted: 120 Post(s)
Reputation Power: 198
Re: Throttle grip help
A pair of visegrips on the bolt head while turning and pulling?
A pair of needlenose pliers behind the bolt head, sideways, to lever outward while turning the bolt?
jondog9 is offline
post #3 of 7 Old 08-21-2017, 8:04 PM Thread Starter
Quoted: 10 Post(s)
That's pretty much what I tried. As I was turning the bolt head with pliers CCW, I had another set on the inside between the bar end and the new throttle grip cap pulling back towards me. but no give
kahlilj is offline
post #4 of 7 Old 08-21-2017, 8:27 PM
Quoted: 120 Post(s)
I wonder which threads are stripped, the bolt or the jamnut inside? Have you tried tapping it inward with a mallet? Just to see if some movement will change things a little?
kahlilj likes this.
jondog9 is offline
post #5 of 7 Old 08-21-2017, 8:31 PM Thread Starter
Quoted: 10 Post(s)
Thanks haven't tried that yet.. still at work but will try that when i get home this evening.. any other suggestions fail that
kahlilj is offline
post #6 of 7 Old 08-22-2017, 12:47 PM Thread Starter
Quoted: 10 Post(s)
THANKS JONDOG!! tapping it with a hammer a few times got it moving inwards and I was able to fasten it down
https://app.box.com/s/bpu9rmrkwq88g6ccg3o6u7vb04dwlv4k
jondog9 likes this.
kahlilj is offline
post #7 of 7 Old 08-23-2017, 3:21 PM
Quoted: 120 Post(s)
I suspect the threads aren't stripped, but the jamnut was just spinning inside the clip-on. Makes sense with what you described.
I had the same problem with one of my old bar-ends after a slight lowside. That's probably how I fixed it too, before getting different clip-ons.
If the jamnut slips and the bar-end loosens, maybe a different length bolt would solve it. I had that issue too.
jondog9 is offline
Throttle grip! suicidebike Honda FireBlade 1 03-07-2014 4:31 PM
Cbr 400 nc23 throttle grip dudejb46 Wanted 4 12-26-2010 10:00 AM
1985 interceptor throttle grip install groove General Discussion 2 04-30-2010 11:22 AM
Pro Grip SCS Carbon Grip & Throttle Kit Big Kahuna Aftermarket Perfomance Parts Reviews 3 05-11-2009 12:39 AM
Throttle cable in grip Glass Honda FireBlade 0 03-29-2007 1:10 PM
