Throttle Position Sensor(TPS) test guidelines - Honda Motorcycles - FireBlades.org
 1Likes
  • 1 Post By speedcrazy1532
post #1 of 5 Old 08-25-2017, 1:45 PM Thread Starter
Quoted: 14 Post(s)
Reputation Power: 3
Searched but could nothing specific in this forum for Fireblades.
The Haynes manual only outlines a test for the power supply to the TPS. I'm almost positive that there exists a test involving backing out the idle screw and measuring:
voltage at each wire X .0something = range
Anyone have this info handy in one of the other manuals?
speedcrazy1532 is offline
post #2 of 5 Old 08-25-2017, 2:40 PM
Quoted: 487 Post(s)
Re: Throttle Position Sensor(TPS) test guidelines
Hi matey, you could try this from the Blackbird site, different coloured wire ,but the method is the same, but before you move the TPS put some marks on the bracket for original position just in case ,it's in message number #9
Testing the TPS on a '98 Blackbird...
MrPickwick is offline
post #3 of 5 Old 08-25-2017, 2:49 PM Thread Starter
Quoted: 14 Post(s)
Reputation Power: 3
Thanks!
post #4 of 5 Old 08-25-2017, 4:28 PM Thread Starter
Quoted: 14 Post(s)
Reputation Power: 3
Ok. So the test listed in the blackbird appears to work on ours which I expected. You need to probe the output voltage wire on the TPS plug which on a 2002 954 is a RED/YELLOW striped wire. The wiring diagrams in the Haynes manual I have seem to have the same color wire for all years 929rr and 954rr.
First step is to turn the idle adjustment knob all the way back so the throttle plates are completely closed.
With ignition on and the sensor plugged in just slowly open the throttle and watch the voltage smoothly climb. The total scale should be .4v at closed to ~5v at wide open. If there are dead spots then you have a problem.
Replacement is possible and there are several models of Honda cars that also use the same TPS. I don't recall which ones off hand but if anyone has input please post it.
The hardest part would be getting the rivets out and tapping it for bolts then setting the sensor correctly so it achieves the .4v to 5v range.
MrPickwick likes this.
post #5 of 5 Old 08-27-2017, 12:43 PM
Quoted: 487 Post(s)
This one I found looks really close to the internals of the Fireblade TPS, think the Honda cbr600f4i 2001-06 is the same also, certainly worth a shot at that price, the only problem I can see with it is the plug connector on the neck of the TPS is on the wrong side
For Honda Accord Civic Acura Integra TPS Throttle Position Sensor 16400P06A11 | eBay
Carbed throttle position sensor? cbrherms Honda FireBlade 6 04-03-2015 3:55 PM
'95 F3 Throttle Position Sensor component Grecoair Honda CBR 600 2 05-31-2013 4:43 PM
throttle position sensor waller Honda FireBlade 8 02-04-2010 10:06 AM
Throttle Position Sensor? pj121905 Yamaha Motorcycles 0 08-21-2008 12:45 PM
Problem with secondary throttle position sensor ucfmotorcycle1 Suzuki Motorcycles 3 03-26-2008 11:39 PM
