954 has no mid range power - Honda Motorcycles - FireBlades.org
 1Likes
post #1 of 18 Old 08-26-2017, 10:33 AM Thread Starter
Recent owner of a 954. Got an issue. I have had it Dyno tuned and went through the bike some. Previous owners removed the exhaust flap, removed the air box flapper and cables. No error light so not sure what he did to eliminate it yet. But even with a dyno, I have no power in the 6-7K range. It is incredibly strong up to 6K and if you stay on it (building speed) it will power on through with no difference. But if you are sitting in the 6-7K range and try to throttle in, you get nothing. Super weak. Almost as if you are over loading fuel or something. You can see a MAJOR dip in the Dyno runs at that range. It is consistent every singe run and every time I ride it. So its not something failing, its purposely doing it. I'm at a loss of what to even check since I don't know this bikes history. Its killing me riding as you will try to accelerate and the engine power just isn't there. Any advice or just a hint of what direction I should be looking in?
sempul is offline
post #2 of 18 Old 08-26-2017, 10:51 AM
Heeza Y Zasch
unslow1's Avatar
Quoted: 388 Post(s)
Reputation Power: 59
Re: 954 has no mid range power
Do you have any images of the dyno sheet you can post?
Does the machine have a Power Commander installed?
There's a very good chance that the HTEV and airbox flapper "missing" contributes to the lack of power, but it's difficult to diagnose with the limited information. My RR2 has both of those deleted (and Servo Buddy installed) but doesn't have a "flat spot" anywhere.
unslow1 is offline
post #3 of 18 Old 08-26-2017, 11:43 AM Thread Starter
I don't have the dyno with me. It does have the PCV installed and tuned.
sempul is offline
post #4 of 18 Old 08-26-2017, 11:47 AM Thread Starter
from reading here, I was thinking check the HTEK valve and see if it is at the 12 o'clock position?
sempul is offline
post #5 of 18 Old 08-26-2017, 4:05 PM
oldbastard's Avatar
Quoted: 60 Post(s)
Reputation Power: 15
I'm guessing its just fuelling. There's normally a flat spot somewhere in the vicinity you describe, as standard, and generally the first time you get the fuelling adjusted with a PC it's fixed. Were you there when they went through the drill?
oldbastard is offline
post #6 of 18 Old 08-26-2017, 7:52 PM Thread Starter
No, but the guy who does it is very very good. People come from over 100 miles away just to use him. I have absolutely no doubt in his abilities. From what I have read on here I'm thinking something is off in my airbox or a valve setting or something. The downside of buying a used bike you know nothing about.
sempul is offline
post #7 of 18 Old 08-26-2017, 8:22 PM
Quoted: 33 Post(s)
What kind of exhaust do you have? To me it sounds more like a mechical or electrical fault. Some sensonr not working properly etc...The HTEV is the exhaust flap.... If anything isn't adjusting it it maybe could cause something like that....
mika_u is offline
post #8 of 18 Old 08-27-2017, 3:39 PM Thread Starter
JTI exhaust with the HTEV valve completely removed along with the flapper.
sempul is offline
post #9 of 18 Old 08-27-2017, 5:01 PM
Quoted: 33 Post(s)
So you have the HTEV replaced with HASS eliminator or something similar? I haven't ever heard of JTI exhaust and doubt they have made a full exhaust to 954....
mika_u is offline
post #10 of 18 Old 08-31-2017, 5:53 PM Thread Starter
its a slip on for sure/
And I don't think it has any type of eliminator that I can see. It looks like the just pulled the guts from the side and bolted a cover over the side. If im looking at it correctly. From more reading it seems that may be my issue since its basically just an open chamber in there now? Basically they just took the flapper and all the guts out and left it hollow. That sound wrong?
sempul is offline
post #11 of 18 Old 08-31-2017, 5:57 PM
Heeza Y Zasch
unslow1's Avatar
Quoted: 388 Post(s)
Sounds like what happens all the time.
unslow1 is offline
post #12 of 18 Old 08-31-2017, 5:59 PM Thread Starter
sempul is offline
post #13 of 18 Old 08-31-2017, 6:54 PM
Quoted: 33 Post(s)
Never seen that happen and doubt it. Why do that when you can just pin the HTEV to certain position. Take the cover of and check the HTEV.
mika_u is offline
post #14 of 18 Old 08-31-2017, 6:56 PM
Quoted: 33 Post(s)
Flapper is in the airbox......
mika_u is offline
post #15 of 18 Old 08-31-2017, 8:45 PM Thread Starter
Its gone and so is the valve in the exhaust pipe. That's the issue lol.
sempul is offline
CBR900RR 918cc snatchey & poor mid range Biggun1 Honda FireBlade 3 06-30-2013 2:14 PM
mods and mid range roadron Honda FireBlade 11 01-27-2009 4:04 PM
RE:Improving the Mid Range on a CBR400 - any tips chaps! marty_400 Honda CBR400RR 6 06-17-2008 3:37 AM
Low-mid range power CBR1000 djdante Honda FireBlade 18 12-09-2006 8:37 AM
Major stumble (mid range) - please help chadcoon7 Honda FireBlade 9 09-30-2005 7:29 PM
