Weird (irritating!) starting problem 929 - Honda Motorcycles - FireBlades.org
post #1 of 2 Old 08-29-2017, 10:15 AM Thread Starter
I have a very weird and irritating starting problem that has emerged, It's a 2001 929. Used to start fine.
Leaving the bike overnight or longer, it often won't start on the starter button. Fuel pump primes (I can hear it) and battery is fine. The motor turns over no problem it just won't fire. I've run injector cleaner through it and replaced the plugs, but no difference.
HOWEVER. If I bump start it, it fires up perfectly fine instantly. Actually I don't even need to do that, just sitting on it and pushing it forward a touch while in gear to turn the motor, and after doing that it then starts on the starter button.
Once it's started, it then re-starts absolutely fine. The bike runs absolutely fine it's only starting that's the issue.
It's only while it's been sitting for a bit that it won't start. And once the motor is turned over by pushing it then starts on the starter button. So I'm thinking it's fuel related, some problem getting initial fuel into the motor, but what specifically? Any advice appreciated!
Elliot is offline
post #2 of 2 Old 08-29-2017, 11:08 AM
Quoted: 487 Post(s)
Re: Weird (irritating!) starting problem 929
Hi ,have you checked for a loose Ignition pulse generator in the crankcase cover
MrPickwick is offline
929 Starting Problem mikecarr4 Honda FireBlade 23 06-22-2018 4:47 AM
weird starting issue, immobiliser problem? oztin275 Honda FireBlade 0 06-01-2015 7:20 PM
929 STARTING PROBLEM Joneal722 Honda FireBlade 0 02-18-2013 8:17 PM
929 problem starting cedric1050 General Discussion 5 11-28-2006 2:14 PM
929 Electrical Problem, Not always starting. Ivo Honda FireBlade 1 10-28-2005 8:28 PM
