929rr motor swap won't run backfires - Honda Motorcycles - FireBlades.org
 2Likes
  • 1 Post By machinehead
  • 1 Post By jondog9
post #1 of 10 Old 08-30-2017, 12:03 PM Thread Starter
My motor went on my 929rr swapped it with a good running motor ran it in the donor bike before it was pulled got it back together was starting hard now it just backfires in the air box and shoots flames out the exhaust
Davin_robinson is offline
post #2 of 10 Old 08-30-2017, 12:48 PM
Quoted: 120 Post(s)
Reputation Power: 198
Re: 929rr motor swap won't run backfires
Timing? Fuel injection issues?
Are you using the 929 ECU? If yes, has it set any codes?
How did you deal with wiring harness - did it all fit?
I've never done a swap like that, I'm sure some here have who could give better advice.
jondog9 is offline
post #3 of 10 Old 08-30-2017, 12:55 PM Thread Starter
Same ecu same wiring everything was exact except air box
post #4 of 10 Old 08-30-2017, 1:01 PM
Quoted: 120 Post(s)
Well, other than the similarities to my bike, I'm kinda out of my league here. But it does sound like timing, hence the ECU question.
Edit, I misread. Sorry. Thought you planted a 954 into your 929. I see you just did a straight swap.
Reading comprehension...
jondog9 is offline
post #5 of 10 Old 09-03-2017, 10:39 PM Thread Starter
It was starting hard but running awesome now just the thing just backfires like that no codes display not a 100% sure on how to read them
post #6 of 10 Old 09-04-2017, 9:56 AM
Quoted: 31 Post(s)
have you made sure all the spark plugs wires are correct order? If the middle two are swapped over, which is very easy to do, it will start but may cause the back-fire you're having. Worth a look anyway.
reading codes is straight forward. Ignition and kill switch off. Short the Check connector RH side by the battery (two pin connector - make sure you've the right thing but the should only be one there!). turn the ignition on and kill switch on, do not start. The bike will power up and the MIL will flash if there are codes stored. if it stays steady red then no codes. if it flashes 6 times that code 6, 1 flash followed by a short gap and say 2 flashes is a code 12. If there is more than one fault logged there will be a long gap between the first code and the next. when it gets to the last code it will start again from the first one again. There is a table of the code in the internet, workshop manual etc. There is also a guide on how to clear the codes but I cannot remember off the top of my head.
Hope this helps.
MrPickwick likes this.
machinehead is offline
post #7 of 10 Old 09-04-2017, 11:01 AM
Quoted: 487 Post(s)
Hope this helps.
MrPickwick is offline
post #8 of 10 Old 09-04-2017, 2:04 PM
Quoted: 120 Post(s)
Try using a period every once in awhile.
chuckhunter likes this.
jondog9 is offline
post #9 of 10 Old 09-04-2017, 8:01 PM
chuckhunter's Avatar
Quoted: 81 Post(s)
Reputation Power: 10
chuckhunter is offline
post #10 of 10 Old 09-10-2017, 12:47 PM
Quoted: 31 Post(s)
I'll go get the Mrs but not sure how her periods help with bad engine running though?>
Help Bike won't run brendonmgg Honda CBR 600 4 10-24-2016 1:37 PM
'93 900RR won't always run AfghanStyle Honda FireBlade 8 07-19-2011 10:39 PM
01 929RR - Won't run, fuel dripping satvic Honda FireBlade 27 02-15-2009 7:54 PM
Engine won't run scuba14c Honda Interceptor / VFR 2 07-21-2007 11:52 AM
WON'T RUN DANIEL General Discussion 9 05-18-2007 1:14 PM
